Hi all,
I'm after some opinions on the best DVD copying software (Paid for... not freeware). I am wanting to backup all of my DVDs onto a hard drive (saved as the VIDEO_TS folder). I am wanting to keep ALL features from original DVD and keep 100% quality as file size is not an issue.
I am completely eliterate when it comes to "computer talk and terminology etc" so I am just after a program with great easy to use features, ability to maintain 100% quality and the ability to remove annoying copyright warnings.... Any suggestions?
Thanks in advance![]()
DVDFabDecrypter (free portion of DVDFab)
...and maybe DVDShrink (free).
No need to pay for anything. Video quality does NOT depend on price paid. -
Buying DVDFab is not a terrible idea, but as the OP is from outside of the USA and Canada, he is much less likely to see those bad sector copy protection programs like ARCCOS, Disney X, etc. He may not have any DVDs that require an up to date DVDFab to rip. Heck, old DVDDecrypter might even do the job too. Having the free DVDFab that is 6 months behind the commercial release should be sufficient for at least 99% of his DVDs. If he has any it won't rip, he can just wait a few months, download a newer version and try again.
What hech54 said. Do not assume paid software is better than freeware. In fact dvdfab hd decrypter, ie. the free part of dvdfab, is the good part. I'll never use the paid/trial part again.
There are tons of posts on this forum from people who are having problems with software they've paid for. The problems are ... they don't work properly. These people unfortunately googled the subject and only looked at the first 6 results. Which, of course, are stacked in google page rank. -
I use AnyDVD HD. I consider it to be the best because it is updated a bit faster (as a general rule) than its main competitor DVDFab. And there are fewer complaints about poorly ripped blu ray with AnyDVD HD, though that is outside of what you want to do. Since you are working with dvds only, you just need the less expensive version of AnyDVD, without the HD capability.
There is no free version of AnyDVD. There is a free trial to test it. You can buy AnyDVD for limited time periods, or pay more for a lifetime subscription.
To rip the dvd, start AnyDVD, put your disc in your dvd drive, let AnyDVD analyze the movie, then right click on the fox icon at the bottom right of your screen. You'll see several options. Select Rip Video DVD to Harddisk. Couldn't be simpler.
Remove Copy Protection Software/Encryption from Commercial DVDS
By dogojoel in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2010, 21:54 -
2009 DVD Copy Software
By hardy in forum DVD RippingReplies: 23Last Post: 1st Jul 2009, 11:35 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Recommendations for dvd-to-zune software? -Corel dvd copy does the trick!
By yoda313 in forum Portable VideoReplies: 7Last Post: 17th Sep 2008, 00:13 -
Free File/Folder Copy Software
By Maikeru-sama in forum ComputerReplies: 5Last Post: 11th Jun 2008, 12:48
