    Jan 2011
    Washington DC Deep in the heart of Taxes
    is there a command line with switches for this? for the output to be an audio file?
    Thanks,
    Paul
  2. http://ffmpeg.org/ffmpeg.html#Examples-1
    For example, on my system:
     ffmpeg -f dshow -i audio="Stereo Mix (Realtek High Defini" -acodec libmp3lame "out.mp3"
    Will record whatever audio is playing on the computer.
    Jan 2011
    I think there is an error on the command line I see an open parenthesis with no closure.. also what would go there if I'm using alsa?
    thanks,
    Paul
  4. There is no error in the command line I gave. That is the name of the Windows device I recorded from. You need to follow the instructions in the link I gave to get the exact name of the device you want to capture from on your computer.
