Since my capture card gives bad results, and since some people here said that I won't be able to get good enough results by buying another capture card/device, I was wondering if getting a miniDV camcorder with analog to digital pass through would be a good option to capture my old VHS tapes.
I have 12 tapes that I need to capture with 1.5 hours on each. I'm wondering if I could buy a cheap used camcorder with that feature so I could capture. Is that possible?
Do HD camcorders also have analog to digital pass through for VCR capturing?
the only one left i know of is the hdv video canon hv40.
turk690, are you able to capture well with that camcorder? It's going for around $70 bucks on ebay, which is less than what I'd have to pay if I took my tapes to those video shops I think.
Does anyone know other old camcorders with this feature? Because I might just buy one used online. -
Its AV to DV function works as expected (that setting is enabled). This is a 12-year old camcorder which I know well. You should find a way to see if stuff on eBay is the same. For example, whoever is selling might have tested his and it plays tapes OK, but the FireWire might not be working (or more commonly the tiny plastic piece on which the four conductors lie on that fragile connector is broken, such as when someone yanks out a FireWire connector sideways with force or shoves the same in at an angle).
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
DV passthrough won't necessarily give any better quality than a capture card. You need an s-vhs deck with a line TBC, or an external line TBC to get good results.
Life is better when you focus on the signals instead of the noise.
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 04:57 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
Camcorders with Analog to Digital Converters?
By heyjjjaded in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th Jul 2009, 14:27 -
What camcorders are best, inexpensive for making Instructional DVD's?
By scenicworld in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2008, 08:29 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2008, 00:18
