Results 1 to 23 of 23
  1. I have a LG BD350 Bluray player. I can play an MKV file from a USB drive but no sound. If I play on the PC I have sound in Win Media player or VLC. I prefer to watch on the TV if possible. any help appreciated
  2. Anonymous
    Guest
    If that mkv has dts-hd or dolby true hd the lg player won't play the sound.
    use mediainfo to find the type of audio.
    If so extract the audio with mkvextract gui (you need mkvtoolnix in the same dir),
    convert the audio to dolby digital and remux with mkvmergegui (MMG, part of mkvtoolnix)
    another possibility is that the mkv contains header compression,
    if so remux with the latest version of MMG.
  3. ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Muxing mode : Header stripping Codec ID : A_MPEG/L3 Codec ID/Hint : MP3 Duration : 1h 22mn Bit rate mode : Variable Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : 504ms Stream size : 75.9 MiB (11%) Writing library : LAME3.90. Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
    this is the media info for audio
    Aug 2006
    It looks like your mkv uses header stripping (header removal compression). According to what I have seen in other threads, you can correct it with MKVtoolnix /mkvmergegui. Go to File->Options and select "Disable Header Removal Compression..." Exit mkvmergegui and restart it so the change will take effect, then open the mkv and make a new mkv.
  5. I tried on DVD will not play audio. audio is mp3 and my player supports mp3
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    That doesn't necessarily mean it'll support MP3 audio in an MKV container. Set-top players do tend to be rather picky about what they'll play. Does your manual specifically state the player supports MP3 audio in an MKV container? If not, you'll probably have to convert the audio.
  7. Originally Posted by Ai Haibara View Post
    Oh did not think of that thanks.
  8. Originally Posted by usually_quiet View Post
    do not understand this bit
    Aug 2006
    I downloaded the manual for your player, and according to the manual, it does not support the .mkv container. Correcting header stripping won't help you.
    It says the following:
    Movie file requirement (USB/DISC)
    Movie file compatibility with this player is limited as follows:
    Available resolution size:
    • DIVX 3.xx – DIVX 6.xx: 720 x 576 (W x H) pixels
    • XVID, H.264/MPEG-4 AVC, MPEG1 SS, MPEG2 PS, MPEG2 TS:
    1920 x1080 (W x H) pixels
    File extensions: “.avi”, “.divx”, “.mpg”, “.mpeg”, “.mp4”
    Playable subtitle: SubRip (.srt / .txt), SAMI (.smi),
    SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt), VobSub (.sub)
    SubViewer 1.0 (.sub), SubViewer 2.0 (.sub/.txt), TMPlayer (.txt),
    DVD Subtitle System (.txt)
    Playable Codec format: “DIVX3.xx”, “DIVX4.xx”, “DIVX5.xx”, “XVID”,
    “DIVX6.xx” (Standard playback only), H.264/MPEG-4 AVC, MPEG1 SS,
    MPEG2 PS, MPEG2 TS
    Playable Audio format: “Dolby Digital”, “DTS”, “MP3”, “WMA”, “AC3”,
    “AAC”
    Sampling frequency: within 32-48 kHz (WMA), within 16-48 kHz (MP3)
    Bit rate: within 20-320 kbps (WMA), within 32-320 kbps (MP3)
    CD-R/RW, DVD±R/RW, BD-R/RE Format:
    ISO 9660+JOLIET, UDF and UDF Bridge format
    Maximum Files/Folder: Less than 2000
    • The movie file name and subtitle are limited to 180 characters.
    • Not all the WMA and AAC Audio format is compatible with this unit.
    • HD movie files contained on the CD or USB 1.0/1.1 may not played
    properly. BD, DVD or USB 2.0 are recommended to play back HD
    movie files.
    • This player support H.264/MPEG-4 AVC profile Main, High at Level 4.1.
    For a file with higher level, the warning message will be appeared on
    the screen.
    • This player does not support the file that are recorded with GMC*1 or
    Qpel*2. Those are video encoding techniques in MPEG4 standard, like
    DivX or XVID have.
    *1 GMC – Global Motion Compensation
    *2 Qpel – Quarter pixel
    All I can say is that if most people were inclined to read the manual for their electronic devices, the traffic at this website would be reduced significantly.
  10. Originally Posted by usually_quiet View Post
    MPEG2 PS, MPEG2 TS
    “AAC”
    movie files.
    the screen.
    DivX or XVID have.
    you are not under any obligation to respond if that is your attitude.
    Aug 2006
    MPEG2 PS, MPEG2 TS
    “AAC”
    movie files.
    the screen.
    DivX or XVID have.
    If being told that you, like most people, are making a mistake by failing to read the manual, offends you, you need to grow a thicker skin.
  12. Originally Posted by usually_quiet View Post
    MPEG2 PS, MPEG2 TS
    “AAC”
    movie files.
    the screen.
    DivX or XVID have.
    nothing to do with my skin not everyone undertannds the manual. Why go to all the trouble of getting the manual just to make a smart comment.
    not wasting my time with you again very busy
  13. I'm a Super Moderator johns0's Avatar
    canada
    Download audacity and the Ffmpeg For Audacity plugin,install both and load the mkv into audacity and export as mkv.ac3.Then load the original mkv and the mkv.ac3 into mkvmerge and uncheck the mp3 and save as a new mkv,then try and see if you get sound.
  14. Originally Posted by johns0 View Post
    Thanks. i am trying to convert it to avi with http://www.leawo.com/video/mkv-avi.html
    Aug 2006
    Funny way of saying "thank you", for providing useful information, since you are converting to a container your player does support, .avi. You're welcome.
  16. my player supports avi and i played an avi from with sound on my player as late as last night
    May 2011
    Here is a simple way to have your LG play this file on your TV,download this little program,, it changes the sound to ac3 its simple to use,it takes about 15 minutes to convert an hour and a half mkv file to a compatible MKV/ac3 file that plays on everything..A 5 year old child can master this program in 30 seconds..and it has very little loss of quality from the original DTS file and it removes automatcly header stripping..Here is the link https://www.videohelp.com/tools?toolsearch=MKV2AC3&Submit=Search&convert=&s=&orderby=Name&hits=50 and your welcome
  18. Originally Posted by RappinRod View Post
    thanks will have a look at that. YES worked very quick. thank you
  19. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    To be fair, I've seen at least one Blu-Ray player (my original Samsung BD player, which is now bricked) 'add' MKV support in firmware updates, before (and not update their manual, online or otherwise, (at least at the time - haven't checked it since the player bricked )). MKV support in those instances (if it actually works) is usually quite a bit more strict than if the player had supported it to begin with, when it first hit retail.
  20. Originally Posted by Ai Haibara View Post
    I know i have watched an mkv before on the the USB . First time i ever saw anyone wanting web traffic slowed lol
    Aug 2006
    I didn't say I wanted traffic to slow down. That's just you assigning intent that doesn't exist, once again.
    However the fact remains that many times people posting questions here wait hours for an answer that could be found more quickly and with less effort on their part by simply looking at their manual.
  22. @RappinRod. thanks , that worked great
  23. i try to ply mkv file on tv through USB. yah it can ply the file but cant here any sound == wat is the problem . RMVB cant also
