I have changed the setting to Type1 and have the playback in preview box with both audio and video (VOB2MPG V3 free edition).
when I click on Start Extraction it generates a single mpeg file in 7 minutes though I am not abe to play it. It stays in the first image not streaming the video...
Results 1 to 10 of 10
Can you play the vob?
What do you play with? Try VLC Media PLayer.
If it fails then open the mpg with mediainfo and change to view->text and copy all the info and post here. -
Thanks for your reply.
yes, I can play the original vob from my dvd using Windows Media Player though cannot play the converted mpeg file with WMP.
As in your advice I can now play the converted mpeg with VLC media player!
But I need the mpg in Windows Movie maker to cut some pieces and create a new shorter version of it. Windows Movie Maker says: it is not valid because it does not contain any information!Last edited by daregazi; 22nd Jun 2012 at 08:36.
Thanks.
I have installed VOB2MPG on my PC. when I run it, I have tried both choosing my DVD drive as the DVD Folder Location and also a Hard drive location where I have copied the DVD to. So it means that the DVD is not copy protected (because I am able to play the video from the Hard drive too).
In both cases the created mpg file cannot be played in WMP. -
If you bought the DVD at a store....there is a 95% chance that it is copy protected in some way.
VLC plays copy protected DVD's. Note, it plays copy protected DVD's. I do it all the time. I just did it again, a minute ago: The Bourne Identity. If that ain't copy-protected, nothing is. Then I loaded Titanic. Played. I played it in PowerDVD, too. Loaded Enemy Of The State. Played.
Then I copied one of the VOB's from the last one, VTS_01_2.VOB. WOuldn't play properly in anything. Period. MediaPlayer just stared at me with a black screen (Muckrosoft? No surprise). Tried to load it into an MPEG editor. No way. Black screen. Showed up in PowerDVD only every 100 frames or so, still-motion. VLC player: heavy pixelation, many disturbances, jerky motion.
Changed the name of the file from vob to mpg. Same problems.
Did you say where you got this DVD, its title? Retail? home made?
It's copy protected. Depending on the algorithms used, the behavior will differ.Last edited by sanlyn; 22nd Mar 2014 at 04:25.
Kill two birds with one stone! Use DVDShrink to decrypt (hopefully it doesn't have the more recent protection) and in preferences untick "split vob files into 1GB etc etc" this will produce a single unprotected vob file. Just change the suffix from vob to mpg and it should work. Otherwise run the big vob file through MPEGStreamclip and convert to mpeg ps. This will strip out of the vob file all the other data.
Conversion of video to mpeg 7 xml
By Rimaz in forum ProgrammingReplies: 2Last Post: 2nd Apr 2012, 15:29 -
MediaCoder x64 build 5175 video noise in DVD vob conversion
By ejai in forum Video ConversionReplies: 6Last Post: 21st Jul 2011, 21:12 -
video conversion to mpg2/vob/h264..
By krohm in forum Video ConversionReplies: 14Last Post: 10th Jun 2009, 15:32 -
VOB Conversion/Video Length
By koberulz in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2007, 16:59 -
No video in VOB to AVI conversion
By Matt42 in forum DVD RippingReplies: 12Last Post: 24th Nov 2007, 22:04
