I purchased a VC500 and have been trying to use it to capture video gameplay footage. The software that came with the capture device (obviously) doesn't capture video in very good quality. I currently have it set to capture the "DVD" option (the options are DVD, VCD, SVCD, MPEG4, AVI, WMV, WMA, and MP3) to capture 29.97 fps at 720x480. However, the video quality is embarrassing to put even on youtube.
First- I'm making sure that the capture settings are proper (or as appropriate as possible with the hardware I'm using)
Second- I'm looking for a program that will capture the best quality I can.
Any help is much appreciated. Thanks in advance.
Comments I've seen about the Diamond Multimedia VC500's pic quality are less than enthusasitic. Some comments seemed a bit enraged. You might try capping to uncompressed or lossless huffyuv AVI and tweaking the results.
A few seconds of a sample capture might help get better answers.Last edited by sanlyn; 22nd Mar 2014 at 03:26.
I guess I need to get a new capture device then. I can't choose which codec to use while recording with this One Touch software. I'll just look for a (hopefully) better capture device that will hopefully come bundled with some better software.
Thanks anyway. -
It's not unusual to have to look around and research a bit when first getting into video capture. Sadly, today's choices are more limited than in the past but there's still some good stuff around. Try the capture cards section here in videohelp.
I believe game play is best captured as direct DV or as losslessly compressed huffyuv AVI. But many go directly to other formats. The problem with lossy compression is that it's difficult to clean up for DVD, but cleanup from game play sources often isn't needed as it might be for, say, VHS or camcorder tapes.Last edited by sanlyn; 22nd Mar 2014 at 03:26.
Which Program Do You Use For Importing Video (MPEG) And What Settings?
By V Bot in forum DVD RippingReplies: 3Last Post: 10th Jan 2012, 00:54 -
What program/settings should I use to capture a home-made 8mm tape? (UK)
By kingmustard123 in forum EditingReplies: 2Last Post: 7th Aug 2011, 11:14 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 16:32 -
Is there any program out there that can determine source settings?
By steve003 in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2009, 12:53
