Hi, I've tried several programs for making a DVD with 4 subtitle and a simple menu for choosing the subtitle. The best one I found was "DVDFlick", but even there I can't get the subtitles to look good, and the menu is weird. I tried tmpgenc authoring works before that, and everything is perfect with it, except that it only allows 2 subtitles per title (wtf?). I've tried many other programs and they're either too complicated (encore), or don't have the functionality I want.
Is there a simple to use app out there that allows you to add 4+ subtitles and create a simple menu for it? (without any fuzz).
Hi Pie
Did you try DVDAuthor with DVDAuthorGUI? In the past it helped me out a lot of times. Small, simple and easy to use, I recall. If I remember correctly it will handle multiple subs (but am not totally sure though).
Cheers
Ennio
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 13:26 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 13:47
