  1. Member gOdiSOnyOuRsIDe's Avatar
    Mar 2004
    I'm recording my gameplay with MSI Afterburner and the program spits out videos encoded in MJPEG video and PCM Audio codec in a AVI container.
    I was up all night deciding what program to use to shrink and edit the resulting file. There are so many programs out it's dizzying. I am familiar with Virtualdub and I'd prefer to use h264 in a MP4 container so I can upload to Youtube.
    As you can see a 20min file comes out to be 21.8GB, too big to upload to Youtube. I'm looking for a simple all-in-one program to compress the file and convert to MP4. The program needs to have simple editing features so I can cut segments of the video to upload instead of the entire video.
    Complete name : G:\vIDEO & sCREEN cAPTURE\bf3_2012_06_18_18_24_49_004.avi
    Format : AVI
    Format profile : OpenDML
    File size : 21.8 GiB
    Duration : 20mn 28s
    Overall bit rate : 152 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 20mn 28s
    Bit rate : 234 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 60.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 4.224
    Stream size : 33.4 GiB
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 20mn 28s
    Bit rate mode : Constant
    Bit rate : 1 411.2 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 207 MiB (1%)
    Interleave, duration : 17 ms (1.00 video frame)
    The further away I get from the things that I care about...
    the less I care about how much further away I get...
  2. you can try avidemux, but vdub can export h.264/mp4 with the external encoder feature ( http://forums.virtualdub.org/index.php?act=ST&f=5&t=18789& ) or through vdub frameserver to another program that exports h.264/mp4
    Also, 60p won't be accepted by youtube (it will be re-encoded to 30p, dropping 1/2 the frames), so there is no use uploading a 60p video
  3. Member gOdiSOnyOuRsIDe's Avatar
    Mar 2004
    I checked the link you gave me but I couldn't find a link for the external encoder feature. I'm using vdub version 1.9.11 x86.
    Thanks for the heads up on 60p, I never uploaded videos to Youtube this will be my first time.
