I used Diamond One Touch Video Capture and its ExGrabber to capture a homemade VSH tape. When I watch the tape on TV (using a VHS player), the sound and video are synced, but after capturing, it is not. It does not seem that there is anything one can do in ExGrabber to prevent this from happening. Am I right?
Can I fix this post-capturing. I have AVStoDVD, but I do not know if that can be used or if some other software is needed.
Thanks for help.
Hans L
One setup available in EZ Grabber is Setup – Record – Record format, which I have set to "DVD" (at your earlier recommendation).
EZ Grabber Setup – Video – Video Format is set to NTSC_M. In addition to PAL and SECAM (not relevant here), it also has NTSC_M_J and NTSC_433. I am not sure what these settings are.
The 720x480, I do not know how to set.
Regards,
Hans LLast edited by Hans L; 22nd Jun 2012 at 08:31. Reason: Just correcting.
My TV captures end up out of sync since I upgraded my WinTV software(not your problem though) but my VHS captures are fine.
I open the MPEG file in AviDemux and resync it there....then do the COPY - COPY - MPEG-PS trick and save a new file.....then delete the old one of course.
It's the easiest way I know how to do it....and with no quality loss. -
Don't be afraid to use high numbers as sync values in programs. Those are in milliseconds. I start at +150 or -150 and "fine tune" from there.
Okay with high numbers, since the delay of the sound is quite noticeable.
I'll get back when I have either succeeded or gotten stuck.
Regards,
Hans L
sound interposition when capturing from tv
By eliqush in forum Capturing and VCRReplies: 0Last Post: 7th Oct 2009, 16:35 -
No sound when capturing video ???
By j4mes_bond25 in forum Capturing and VCRReplies: 6Last Post: 10th Aug 2009, 11:03 -
Capturing analogue under vista Sound twice as fast as video
By djain91 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2008, 17:36 -
unsync video
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 07:00 -
Portable DVD Player Audio/Video Unsync Problem
By wicious in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 08:14
