Okay. I have a dvd disk, and it contains VIDEO_TS (the whole video) and few parts like "VTS_01_1" "VTS_01_2" "VTS_01_3" "VTS_01_4" and "VTS_01_5"
And I found a scene that I want to delete. I'm guessing since video_ts is 14kb, it loads these "VTS_01_1" etc parts and that's how the video is played.
The scene I want to delete is in "VTS_01_5". So I just opened it with movie maker, delete the scene I want to, and then when I exported it it was wma file. So I took some wma to .vob file converter and coverted it. Then I deleted original "VTS_01_5" from folder, and put my converted file and named it "VTS_01_5".
But when I open video_ts and video starts playing, it's just not working.
Everything is working and then when it should load like the last 8 minutes of the video (that's when it should load VTS_01_5) it can't load. It just ends the video.
But when I put original VTS_01_5 (original not edited) then it works good.
So I don't know is there anything I should do with my edited version of VTS_01_5 to put it into to the whole video or what?
I would really appreciate any help. Thanks
It doesn't work that way. You cannot edit a VOB file then stick it back inside the VIDEO_TS folder.
Okay. Is there any other way to delete that scene from .vob file ? it's like 10 seconds scene I want to delete. Thanks for the reply
You can instead use vobblanker. It's not that easy to use but with help of some guides you might get it to work, read http://www.dvdr-digest.com/articles/article_vobblanker_page1.html and http://download.videohelp.com/jsoto/guides/VobBlanker/prevcut/index.php
Actually I have one more problem.
Everything works good when I open it on my pc. But when I burned it on my dvd disk and when I insert dvd disk and try to play it, I get an error "Your input can't be opened: VLC is unable to open the MRL 'dvd:///E:/'. Check the log for details."
Is there a special way to upload these files or ? Also, there's no audio folder. Is that a problem ? I just opened power iso, put all files and burned on cd. Maybe I should do something else when burning ?
question on vob files
By rtr720 in forum Authoring (DVD)Replies: 12Last Post: 17th Jan 2010, 12:00 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15 -
Question about editing VOB files
By C0SM0 in forum EditingReplies: 19Last Post: 26th Feb 2008, 19:53 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 17:56
