I am trying to create a DVD from an AVI file (with subtitles in IDX and SUB) using AVStoDVD. Although two or three preliminary steps run successfully (taking about 70 minutes), consistently MuxMan aborts without doing anything. I get the same error message instructing me to examine the log files.
Several times now I have made minor changes to the configuration (such as changing Chapters Interval to 999 minutes) in accordance with the suggestions at this site only to run it again and find that MuxMan fails within a second or two. I cannot even see a way to test this specific problem without restarting the whole process, at a cost of some 70 minutes' delay.
Here are the log files. I would appreciate any assistance.
DVD_1
<2012.06.19 17:29:50>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\XXX\Videos
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 0
AC3 Audio Encoder: 1
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 999
Use Source Chapters: 1
DVD Burning Drive: E: MATSHITA DVD-RAM UJ8B0AW 1.00
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: C:\Users\XXX\Downloads\YYY\YYY.avi
Info: XviD - 1021 kbps - 624x464 - DAR 1,345 - 0 fps (CFR) - Progressive - 1:35:53 hours - 137937 frames
Audio 1: C:\Users\XXX\Downloads\YYY\YYY.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:35:53 hours (0 ms delay) - Internal
Subs 1: C:\Users\XXX\Downloads\YYY\YYY.idx
[MediaInfoLib - v0.7.50]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Users\XXX\Downloads\YYY\YYY.avi ", CacheFolder="C:\Users\XXX\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("C:\Users\XXX\Downloads\YYY\YYY.avi ", CacheFolder="C:\Users\XXX\AppData\Local\Temp")
Video = Video.ConvertToYV12
Video = Video.AddBorders(0,2,0,2)
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 4214,3 MB
HCenc Parameters: -ini "C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY.HCenc.i ni"
HCenc ini file:
*INFILE C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY_1.avs
*AVSRELOAD
*OUTFILE C:\Users\XXX\Videos\DVD_1_YYY.m2v
*LOGFILE C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY.HCenc.lo g
*MAXBITRATE 9000
*1PASS
*BITRATE 6145
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2012.06.19 18:13:28>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: AVISource
Created File: C:\Users\XXX\Videos\DVD_1_YYY.m2v (4215,8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6197 kbps - 720x480 - DAR 1,333 - 0 fps (CFR) - Progressive (TFF) - 1:35:47 hours - 137799 frames
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg (WAV) Parameters: -i "C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY_1.a vs" "C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY_1.w av"
Aften (AC3) Parameters: -b 192 -pad 0 -dynrng 5 -bwfilter 0 "C:\Users\XXX\AppData\Local\Temp\DVD_1_YYY_1.w av" "C:\Users\XXX\Videos\DVD_1_YYY_1.ac3"
<2012.06.19 18:40:39>
END AUDIO ENCODING OPERATIONS (Track 1)
A2DAudioSource: DirectShowSource
Created File: C:\Users\XXX\Videos\DVD_1_YYY_1.ac3 (131,6 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:35:50 hours (0 ms delay)
START SUBS ENCODING OPERATIONS (Track 1)
VSConv Parameters: -f sup -i "C:\Users\XXX\Downloads\YYY\YYY.idx" -o "C:\Users\XXX\Videos\DVD_1_YYY_1" -id 0
<2012.06.19 18:40:40>
END SUBS ENCODING OPERATIONS (Track 1)
Created File: C:\Users\XXX\Videos\DVD_1_YYY_1.sup (2,08 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\XXX\AppData\Local\Temp\DVD_1_BatchMux.in i"
BatchMux ini file:
-d "C:\Users\XXX\Videos\DVD_1\VIDEO_TS"
-mxp "C:\Users\XXX\AppData\Local\Temp\DVD_1_MuxMan. mxp"
-l "C:\Users\XXX\AppData\Local\Temp\DVD_1_MuxMan. log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\XXX\AppData\Local\Temp\DVD_1_Palette.txt "
-v "C:\Users\XXX\Videos\DVD_1_YYY.m2v"
-vidmode 4:3
-a1 "C:\Users\XXX\Videos\DVD_1_YYY_1.ac3"
-a1lang en
-s1 "C:\Users\XXX\Videos\DVD_1_YYY_1.sup"
-s1lang en
-s1ext 1
-cellfr "C:\Users\XXX\Videos\DVD_1_YYY_Chapters.txt"
-progfr "C:\Users\XXX\Videos\DVD_1_YYY_Chapters.txt"
-chapfr "C:\Users\XXX\Videos\DVD_1_YYY_Chapters.txt"
<2012.06.19 18:40:51>
Process aborted during DVD AUTHORING operations!
Check following files for more details:
AVStoDVD log file <C:\Users\XXX\Videos\DVD_1.log>
BatchMux log file <C:\Users\XXX\Videos\DVD_1_BatchMux.log>
<2012.06.19 18:40:53>
Log file created by AVStoDVD Release 2.4.2
DVD_1_BatchMux
BatchMux version --> 1.3
Destination Folder --> C:\Users\XXX\Videos\DVD_1\VIDEO_TS
MuxMan Script File --> C:\Users\XXX\AppData\Local\Temp\DVD_1_MuxMan.mxp
MuxMan Log String --> -l "C:\Users\XXX\AppData\Local\Temp\DVD_1_MuxMan. log"
Folder of the MuxMan executable --> C:\Program Files (x86)\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Palette File --> C:\Users\XXX\AppData\Local\Temp\DVD_1_Palette.txt
Default Palette --> SUCCESSFULLY REDEFINED
Segment #1 - Video File #1 --> C:\Users\XXX\Videos\DVD_1_YYY.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x480)
MPEG-2 Aspect Ratio (DAR) --> 4:3
WARNING - Frame Rate Code 1 not allowed for DVD.
Video Frame Rate can not be established.
Proceeding by setting it to 29,97 fps.
Video Bitrate (Nominal, Kbps) --> 8789
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> 4:3
Segment #1 - Audio #1 File #1 --> C:\Users\XXX\Videos\DVD_1_YYY_1.ac3
Segment #1 - Audio Lang Code #1 --> en
Segment #1 - Subpicture File #1 --> C:\Users\XXX\Videos\DVD_1_YYY_1.sup
Segment #1 - Subpic Lang Code #1 --> en
Segment #1 - Subpic Lang Ext #1 --> 1
Segment #1 - Timeframe file --> C:\Users\XXX\Videos\DVD_1_YYY_Chapters.txt
Segment #1 - Total Nr of Cells --> 16
Segment #1 - Total Nr of Programs --> 16
Segment #1 - Total Nr of Chapters --> 16
Started preparation of --> MUXMAN SCRIPT
Completed preparation of --> MUXMAN SCRIPT
MuxMan RunString --> -run
Strings (local stack - bytes) --> 1278
Time Codes (local heap - bytes) --> 589
Static memory usage % --> 1.42
Starting MuxMan Authoring with --> LOW task priority
MuxMan Authoring --> COMPLETE
Printing out --> MUXMAN LOG
-- MuxMan version 0.15R
-- Opened script file C:\Users\XXX\AppData\Local\Temp\DVD_1_MuxMan.mxp
-- Rejected sp r/fr C:\Users\XXX\Videos\DVD_1_YYY.m2v
-- Accepted audio C:\Users\XXX\Videos\DVD_1_YYY_1.ac3
-- Opened sub 1 file C:\Users\XXX\Videos\DVD_1_YYY_1.sup.
-- No video file declared
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
Results 1 to 17 of 17
Thank you for the suggestion. I do not know why the frame rate is 0 fps; I obtained the file from someone else, and it works just fine when I display it with Preview Title Output (in AVStoDVD) or with the Windows Media Player.
By «repack», do you mean that I should open the file and save it again? VirtualDub was going to turn this 0,8 GB file into one of some 160 GB, so I gave up on VirtualDub and tried Avidemux instead. Avidemux said to use Tool→Rebuild Frame; then it wrote a file of roughly the same size. That file works correctly in the Windows Media Player, but there is no sound in Preview Title Output. -
I used Avidemux to convert the file to MP4. This time both the audio and the video worked in Preview Title Output, and AVStoDVD reported that it had successfully built the project (although there was a message at the end about skipping the conversion of the audio).
I didn't know that it was necessary to specify «Burn DVD» from one of the menus. Just now I specified that, and the whole process (more than an hour and a half) started over again. I hope that it will work this time. -
I just compared the DVD (the files used to produce it seem to have disappeared) with the MP4 file. Apparently the video on the DVD starts about 27 seconds too early: a scene that appears at 2:00 in the MP4 file appears at 1:37 on the DVD, although the audio in both versions starts (correctly) at 2:00.
Thanks. I'll find a way to upload the file.
I have used Avidemux to generate both MP4 and MKV. Both files work correctly in the Windows Media Player but exhibit the same defect (audio and video approximately 25 seconds out of synch) in AVStoDVD (Preview Title Output). So I am inclined to think that the problem lies in my installation of AVStoDVD—either in the software itself or in my configuration or use thereof. -
I wouldn't be so sure myself ... I found the one thing avstodvd really had over other dvd encoder/authors was the ability to work with files that had weird non standard codecs that the original ripper/encoder had on their machine.
It would help to clear things up if you used mediainfo on the file and posted the results. Every computer media user should have that program.
I've used avidemux as suggested above on problem videos. It almost always worked ... avidemux uses very, very good internal libraries and will read almost anything that isn't broken.
Note I said almost anything.
In addition to potential codec problems, there are a lot of video files floating around out there that are simply encoded wrong. Either the ripping/encoding software was junk without proper settings, or the software was good but they didn't have a clue how to use it. The latter issue is very common. Video encoding standards are complicated and designed for pros.
Those types of bad video may play in smplayer or vlc but they won't work all that well, and they won't encode to dvd compatible format very well at all. -
The file itself may well be incorrectly encoded. I do not know its provenance (probably some Web site) and could not attest to its quality. Someone gave me the file and asked me to put it onto DVD.
But something must be wrong when the file plays correctly in the Windows Media Player but not in AVStoDVD (Preview Title Output).
In any event, here are the reports from Mediainfo, for both the original AVI and the MP4 that I generated with Avidemux. Note that the frame rate, which consistently appears as 0 fps in AVStoDVD, is shown here as 23,976 fps.
AVI
General
Complete name : C:\Users\XXX\Downloads\YYY\YYY.avi
Format : AVI
File size : 795 MiB
Duration : 1h 35mn
Overall bit rate : 1 159 Kbps
Writing application : transcode-1.0.2
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 35mn
Bit rate : 1 022 Kbps
Width : 624 pixels
Height : 464 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.147
Stream size : 701 MiB (88%)
Writing library : XviD 1.1.0 (UTC 2005-11-22)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 35mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 87.8 MiB (11%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Writing library : LAME3.96.1
MP4
General
Complete name : C:\Users\XXX\Downloads\YYY\YYY.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 792 MiB
Duration : 1h 35mn
Overall bit rate : 1 155 Kbps
Movie name : YYY.mp4
Writing application : Lavf53.24.0
Video
Format settings, BVOP : Yes
Codec ID : 20
Duration : 1h 35mn
Bit rate mode : Variable
Maximum bit rate : 9 500 Kbps
Width : 624 pixels
Height : 464 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 6B
Duration : 1h 35mn
Bit rate : 128 Kbps
Writing library : LAME3.96.1 -
I'm just downloading the AVI right now.
In the meanwhile, could you make this attempt:
1. Load the original AVI into AVStoDVD
2. Go to 'Edit Title'/'Edit Source Title Info'/'Video Framerate'
3. Insert 23.976 (be careful to use . and not , as decimal separator)
4. Run the project
Bye -
Thank you for examining the file.
Just now I set the video frame rate as you indicated; however, I got a warning stating that the value was invalid. Now the sound starts a good 15 or 20 seconds before the video, whereas previously it started after the video. -
Actually, it seems to be working now, at least in Preview Title Output. I selected XviD under Source Titles and then entered the frame rate as you suggested, and now it works. Then again, it also previously worked in Preview Title Output, although the project wouldn't build.
I'll try to run the project now.Last edited by psh1; 21st Jun 2012 at 15:44.
Could you post the log file?
Meanwhile I have tried to convert the AVI you sent me. Just trimmed few frames (3000) to speed up the test. No issues. See log file.
Some other trials, one by one:
- Give a try to latest AVStoDVD 2.5.0 alpha release
- Change the system decimal separator from "," to "." in Windows International Settings
- Uninstall and reinstall AviSynth
Let me know
Bye
AvsToDVD aborts during finalisation
By alhenderson in forum Authoring (DVD)Replies: 25Last Post: 15th Jan 2013, 17:53 -
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum Capturing and VCRReplies: 8Last Post: 30th Jul 2012, 13:14 -
Unable to extract audio - BD-Rebuilder aborts
By mobie29 in forum Blu-ray RippingReplies: 4Last Post: 7th Apr 2011, 10:19 -
Capture aborts when media format changes
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd May 2008, 18:09 -
Nero 7 Ultra Edition Aborts DVD to Burn
By uLmighty in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2007, 03:02
