I bought a cheap little NTSC JVC VCR on Ebay for $1 the other day. It arrived. It has a power cable with an American 110V plug on the end....and an adapter over that with a European 220V plug. Doing a quick check on Google...it says that this VCR can do both and switch automatically.
http://tv.manualsonline.com/manuals/mfg/jvc/hrj4009um.html
I've never seen that before.....I'm afraid to plug it in.
Oh it's a little "crapper"....not even STEREO.
It would be safer to just use a 220-> 110 V converter. If you plan on investing in more US stuff definitely work the 10€ investment
Channeling some of our more caustic responders . . . . . What part of "autoswitching" is confusing?
You plug it into a 110 v socket, using the standard US plug, it notes the voltage and runs . . . .
You plug it into a 220 v socket, using the adapter, it notes the voltage and runs . . . .
Most laptops/netbooks do the same thing (I've done it many times during visits to the UK, with appropriate adapter), but many don't go the nice extra feature of proving the adapter.
. . . and you're only gambling a buck . . . .
Your mileage may vary . . . . -
So the point is whether or not you will fry your VCR or what?I already have one....that is not the point.
CobraPilot is right. If it is like a laptop you can theoretically plug it in anywhere and it should work.
My experience has been that anything mechanical (hair dryers/raisers) though usually does not like going back to 110 V after being used in Europe. -
The JVC HR-S7965EK has a 110-240V ~ 50-60W power supply.
It's not that uncommon on the better models.
It's more rare on consumer items.
Power step up/down converters often add power noise, so use the VCRs native power abilities.Want my help? Ask here! (not via PM!)
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 09:45 -
MKV on Pioneer DV-220V
By Instant Martian in forum DVD & Blu-ray PlayersReplies: 7Last Post: 8th Jun 2011, 11:18 -
Pioneer DV-220V-K DVD player for canadians June 21,2010
By jakeconnor in forum DVD & Blu-ray PlayersReplies: 14Last Post: 11th Nov 2010, 20:16 -
Pioneer DV-220V-K firmware version?
By batyar55 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Jun 2010, 14:27 -
Pioneer DV-220V - region change code and PAL?
By EVG in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Apr 2010, 11:34
