Hi,
I am looking for a programming language that would suit development of an application that could process video feeds for motion detection and object recognition. Would like to have this running on a Linux platform, and trying to keep it as open-source as possible. I have experience with Java so that would be my preference. I have briefly looked into some Java graphic libraries, JMF being the default but is no longer maintained. Have also looked into Xuggle, GStreamer and v4l4j.
C/C++ tends be more efficient, so I guess would Java be suitable for video processing? If Java is not the way to go please let me know what you would suggest or have used in the past.
I have seen one example app called Motion, this was developed using C and the video4linux interface.
I don’t want to start a technology debate, just any ideas would be appreciated, either comments on languages you have used, API/libraries that were useful – in particular with motion detection, video and image manipulation capabilities.
Cheers
libav might be worth a look at,... (C/C++)
also MLT (http://www.mltframework.org) might be interessing as video frame work (c/C++) -
Hi,
FYI - I decided on OpenCV based on the community, power of the library and doc/tutorials available. Will be using C++ also, not keen on the Java bindings/libraries, need to keep as efficient as possible.
Cheers
Question about listening to audio streams from university libraries
By jimdagys in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2012, 10:28 -
Good Languages vs. Bad Languages?
By hech54 in forum FeedbackReplies: 8Last Post: 17th Mar 2012, 13:56 -
Audio Video Libraries and Viruses
By Bonie81 in forum Newbie / General discussionsReplies: 5Last Post: 16th Jul 2011, 18:49 -
Multiple audio languages and subtitle languages
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2009, 12:44 -
Encore CS3 Libraries
By vin4evr in forum Authoring (DVD)Replies: 0Last Post: 20th Feb 2008, 10:46
