Okay I am converting my various DVR-MS and WTV files to mp4 using MCE Buddy. Since these are archived for playback using XMBC and not Windows Media Center which I will continue to use as a DVR, file type, fast-foward/rewind are less of an issue.
I want to get the preset right. So far with the files I have picked out for experimentation, turn a 1.5GB+ file into a 390-400MB file (great!), but I see the resolution is off because I get the (noise) at the top of the picture.
Questions:
Can I get the correct resolution (640x480) for a file I converted using Windows Live Movie Maker, instead of the 704x480 which creates the "noise" at the top of the screen?
That isn't really a question, as I know things like resolution can be changed with the GUI. But just wanted to make sure
The other questions are:
How small can I make these? I'm confounded WMC makes these files so huge and don't even use WMA which is only 100MB larger than another file from the same show converted to H.264 (400MB). Since I started using XBMC (Media Browser before that), I have given up trying to play these back inside WMC and keeping the Metadata. So to have even more space on my 2TB drive, I wanna know how much smaller I can make this and MAYBE retire my external drives on my HTPC, since the majority of the files on there are SD and in WTV (or DVR-MS).
Is One Pass enough or should I do 2 Passes on SD files?
Results 1 to 1 of 1
Project Digital: Eliminate All Physical Media is finally underway!
Vegas Pro proper render settings
By ingeborgdot in forum EditingReplies: 24Last Post: 20th Sep 2011, 16:01 -
Proper Handbreak Xvid settings
By A_51 in forum DVD RippingReplies: 3Last Post: 22nd Feb 2011, 19:26 -
Sony Vegas - PROPER settings for YouTube
By Bucic in forum Video Streaming DownloadingReplies: 21Last Post: 14th Jun 2010, 14:28 -
Using MeGUI downscaling to 720p. What are proper settings ?
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 1st Nov 2009, 19:40 -
MCE buddy output format
By articaine in forum Video ConversionReplies: 3Last Post: 11th Oct 2009, 16:14
