DVD Architect Pro 5.2 is placing black bars on top and bottom and both sides of the video. The aspect ratio looks correct. Except that the menu is correct and going all the way to the edges of the screen. I set up 1920 X1080 video to be 720X480 video in the properties in Vegas Pro 10 and then render with the DVD Architect Pro widescreen template. I set video with DVD Architect Pro to 16:9 and the preview has a vertical thin black lines on each side (which is acceptable), but otherwise fills the screen. When I process with DVD Architect Pro and watch the extracted ISO on Videolan computer player, the video does not fill the screen, but the menu does.
when you rendered the mpg2 did you put a check in the box to "stretch video to fill output frame - do not letterbox"?
Hey Thanks,
That worked on a short test rendering. Will do full rendering tonight.
Audio POPS! with DVD Architect Pro 5.0
By Dissonance in forum Authoring (DVD)Replies: 2Last Post: 21st May 2012, 16:45 -
Is there something better than DVD Architect 5 to use with Vegas Pro?
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 12th Dec 2010, 21:46 -
DVD Architect Pro v5.0b Help - Gaps Between Chapters
By shawncumby in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2010, 01:23 -
DVD Architect Pro 5.0 Help - Introduction Media Help
By shawncumby in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2010, 17:34 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51
