Hello,
For non-professional usage, I need a shotgun microphone to connect to my Sony camcorder that would cost around $200:
- Can be screwed on a grip handle or at the end of a stand to pick up lectures from a loudspeaker
- Can take a wind cutter/dead cat for the occasional outdoor recording
- Mini-jack, and possibly XLR
- Runs on batteries, and possibly phantom power
I see several models from AudioTechnica (ATR 6250, AT 897) and Rode (NTG-2, Videomic Pro), as well as the Senheiser MKE 400. What do you think? Are there other brands I should know about?
Thank you.
Results 1 to 11 of 11
i use the rode stereo video mic pro on canon dslrs and love it. the rode mono shotguns also get good reviews.
Thanks for the info.
I don't understand how a shotgun mike can record in stereo since it ignores sound coming sideways? Does it make a difference whether I buy a mono instead of a stereo?
My camcorder doesn't provide a way to screw the mike on top or side, so hopefully RØDE's VideoMic Pro can be screwed on a handle grip.
What's the difference between the VideoMic (Pro) and the NTG-x series? -
aedipus said that he uses the rode stereo videomic pro and that the rode mono shotgun videomic pros are also highky rated. He did not say that the stero mike he uses is a shotgun mike. For the record, the Rode Stereo VideoMic Pro is not a shotgun mike.
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Strange, their web site says that "The RØDE VideoMic Pro is a true shotgun microphone designed for use with camcorders, DSLR cameras and portable audio recorders as a source of primary and reference audio." And there's also the NTGx series. And AudioTechnica, and other brands. Lots of choices.
Ideally, it could be hooked to Sony's propriety shoe on top. -
http://www.kiva.org/about -
if you want cheap and maybe a little better than the built-in, go ahead and buy the sony.
http://www.bhphotovideo.com/c/product/367193-REG/Sony_ECMHGZ1_ECM_HGZ1_Shotgun_Zoom_Mic.html--
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11 -
XLR to 3.5mm shotgun mic
By Gerrysw in forum AudioReplies: 10Last Post: 30th Dec 2011, 17:36 -
Shotgun Mic for Canon Vixia HF S20
By amriteshvara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 18th Jul 2011, 14:37 -
Shotgun mic for Sony DVD-405
By gmcman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th May 2010, 21:30 -
Looking for a cheap shotgun mic
By 872156 in forum AudioReplies: 8Last Post: 13th Jul 2009, 21:25
