The best performing real-time software mpeg encoder seems to be the Ligos encoder. I have tried others like the Nanocosmos and PowerVCR, but Ligos seems to perform the best. The only stand-alone capture application software I know of that use the Ligos encoder is the Ulead Videostudio. Are there any other capture applications that use the Ligos encoder that will work with a regular WinTV capture card?
Vegas Video 3 uses Ligos gomotion for MPG1 and MPG2 for their generic MPG encoder, VV3 also has the Main Concept MPG encoder. I don't see much difference between them though.
Capture in Vegas is mainly for DV but I have captured using my old WinTV card in the Vegas 2 capture app. Or you could capture using another app. and use Vegas to edit and render.
codec
By natty in forum Newbie / General discussionsReplies: 22Last Post: 3rd Apr 2011, 13:42 -
Which codec?
By Andyncu in forum Video Streaming DownloadingReplies: 5Last Post: 13th Feb 2011, 08:11 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
