I've got a 1080p file that my PS3 is refusing to play (black screen/audio only) so I'm trying to understand what aspect/s of the file are causing the issue (MediaInfo details pasted below).
Can someone confirm that the issue (or is there more than one) is the 5 Reference Frames? I've read that 3 or 4 is the upper limit for PS3 due to memory limitations?
(I tried using H264 Level Editor to reduce the level to all options of 4.x and 3.x which didn't help - though my Samsung TV did play the file from a usb stick when I set it to 4.2).
If there's no easy tweak to file parameters to fix the PS3 issue and a reencode is necessary can someone recommend the easiest and fastest free windows-based GUI tool to perform a reencode (my preference is to keep the output as mp4) please?
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 349 MiB
Duration : 15mn 37s
Overall bit rate : 3 126 Kbps
Writing application : Lavf52.86.0
Video
Format : AVC
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Duration : 15mn 37s
Bit rate mode : Variable
Bit rate : 3 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.060
Stream size : 335 MiB (96%)
Writing library : x264 core 108
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.41 / aq=1:1.00
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 15mn 37s
Bit rate : 122 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 13.6 MiB (4%)
Language : English
Thanks - trying a reconvert with vidcoder but vidcoder also has a wide array of options on the advanced settings menu - is it worth trying to use the defaults?
I'm really keen to understand whether it is the ref frames that are the issue so I can e.g. set the ref frames to 3 on vidcoder and then eliminate that as a cause for the PS3 refusing to play.
Ps3 Black screen on movies
By Fenrirjack in forum Blu-ray RippingReplies: 10Last Post: 21st Dec 2011, 18:18 -
AVCHD playback problems on PS3, black screen at midway point
By mikeveli20 in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Mar 2011, 13:46 -
Add srt to MP4 for PS3 Playback
By marioval in forum SubtitleReplies: 5Last Post: 11th Jan 2011, 08:05 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
black screen on ps3 after converting video
By unknownguy in forum Video ConversionReplies: 1Last Post: 22nd Jan 2009, 07:26
