I've recorded a few things off air, intending to watch in another room using DLNA. Everything was OK until some programs wouldn't play, you select them from the menu and you're immediately returned to the menu.
Using Twonky I could see differences, first the file size was 0 Bytes, and the format description is -
Format: application/x-dtcp1;DTCP1HOST=10.1.1.6;DTCP1PORT=60010;CONTENTFO RMAT=video/vnd.dlna.mpeg-tts
Files that do play show as -
Format: video/x-msvideo (and have a file size)
Suspecting these are copy protected, I copied one to a disk and that was OK - although I can only copy to DVD, not BluRay.
Does anyone know what's behind this? The recorder is a Panasonic DMR-XW380 but crippled for NZ so we can't easily skip ads.
Thanks!
anything with a file size of 0 is an empty file. nothing got recorded.
Try running chkdsk to see if there are any file fragments that can be recovered.
Hi,
Chkdsk runs OK and the file isn't fragmented. The 0 bytes is reported by Twonky from the DVD-R HDD, but after copying to the PC, Explorer shows how big it is. But it won't play in anything, even Mediainfo shows just the filename.
It must be the Panasonic is not 'releasing' the file in a usable form. Yet, not all of them, some are fine. Is it copy protection imposed by the broadcaster? Would they copy protect the news? And they are copyable to an optical disk.
Best TV brand for DLNA?
By trevytrev in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2014, 10:00 -
Need DLNA software
By mlong30 in forum Software PlayingReplies: 11Last Post: 1st Mar 2013, 08:07 -
By trevytrev in forum Software PlayingReplies: 1Last Post: 30th Dec 2011, 00:58 -
Media Server DLNA Suggestion
By wubsjk in forum Video Streaming DownloadingReplies: 10Last Post: 27th Dec 2010, 10:02 -
DLNA (external disks to TV)
By rascar in forum Software PlayingReplies: 4Last Post: 23rd Aug 2009, 13:38
