What constitutes use of a Dual Layer disc....running time or bitrate? I never understood that.
Obviously this file is too big for a single layer by size....
Format : MPEG-PS
File size : 6.66 GiB
Duration : 1h 40mn
Overall bit rate : 9 503 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 1h 40mn
Bit rate mode : Variable
Bit rate : 7 778 Kbps
Nominal bit rate : 8 255 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.750
Stream size : 5.45 GiB (82%)
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : DVD-Video
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 1.08 GiB (16%)
Should I just author this as a Dual Layer disc and burn it. Is this bitrate too high for DVD Specs?
This is from a VHS source so it goes against my own advice that a super-high bitrate is a waste
of space for VHS sourced stuff....but I want to keep this original capture untouched.....and I wanted to
play with my newly acquired S-VHS with TBC.....I think I overdid it.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Very Newbie Question: Can I Write Dual Layer?
By dadada_999 in forum DVD RippingReplies: 2Last Post: 9th Apr 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
