I have burnt a video in a disk using dvd flixk/imgburn. the video when played in TV is good but audio I can hear direct from TV but if I connect my headphone to TV there is no audio in the headphone. there is no problem with head phone because I can hear other channel programmes in the TV through headphone. any suggestion is welcome. thank you
Mono headphones? Does your TV have a balance setting for the audio? If so, try turning it all the way to the left or right. Do you hear anything now?
Some TV's supports independent volume adjustment for speakers and for headphones. This can be your case.
Check configuration and adjust/set correct volume.
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 21:39 -
Any ideas on why audio through headphone jack stutters on MacBook?
By ryangarfield in forum ComputerReplies: 2Last Post: 30th Mar 2010, 22:07 -
Record audio from PC headphone output
By Galadirith in forum AudioReplies: 0Last Post: 25th Jun 2009, 12:43 -
Can audible magic be bypassed through padding audio?
By diddyman4real in forum AudioReplies: 0Last Post: 5th Dec 2008, 17:48 -
audio from recorded tv episode to dvd barely audible
By rancid in forum AudioReplies: 2Last Post: 2nd Jan 2008, 18:00
