the Avisynth MT 2.5.8 dll hasn't been updated for multiple years and nobody recommends it usage, so the actual user count of users using it is probably really slim.i was really hoping that some one would have Set's Avisynth.dll and share
Results 61 to 90 of 106
And it won't speed up fft3dfilter (vs. 2.6MT). Check Task Manager while it's running. If you don't see near 100 percent CPU usage bump up the number of threads. Also beware that the source filter or encoder could be another bottleneck.
Your script runs at about 55 to 60 fps with 80 percent CPU usage on my i5 2500K with 2.6MT.
Setting the number of threads to 5 brings the frame rate up close to 65 with ~100 percent CPU usage.Code:SetMtMode(5,0) Mpeg2Source("NTSC_DVD.d2v", Info=3) SetMtMode(2) ColorMatrix(hints=true, threads=0) crop(0, 56, 0, -56) LanczosResize(608,256) fft3dfilter(sigma=1.0, bt=5, bw=32, bh=32, ow=16, oh=16, sharpen=0.4) LSFmod( strength=75, smode=3, soothe=true, keep=20, edgemode=0, edgemaskHQ=false)Last edited by jagabo; 29th Mar 2014 at 08:07.
so using "SetMtMode(5,0)" is slower than using "SetMtMode(5,5)" on your system. Interesting, may be I should do some tests somewhere in the future which filters get faster if you use more then the (virtual) core count. (not sure if a i5 2500k support hyperthreading or notSetting the number of threads to 5 brings the frame rate up close to 65 with ~100 percent CPU usage.
no, jagabo suggested that it might help to use a even higher thread count.
I know some users, which always use 2*'virtual' core count in their scripts, which would be SetMtMode(5, 16) for the i7 4770 and and SetMtMode(5, 24) for the i7 980X.
-> like I mentioned some further investivating into which filters profit from this (I know not all do) and which don't might be a good idea. -
The number of threads required for maximum performance varies from script to script. It' usually somewhere between 1x to 2x the number of cores (as seen by Task Manager, ie CPU threads). But sometimes it's outside that range.
when i add the AVS script i get the following error's
http://prntscr.com/356wt0
http://prntscr.com/356x0p
Script
Download from here https://code.google.com/p/avisynth-mt/downloads/listCode:SetMTMode(2) LoadPlugin("C:\Users\Administrator\Documents\Megui\tools\ffms\ffms2.dll") FFVideoSource("D:\Dwnloads\hamm_HD_1280.mp4") RequestLinear(rlim=50,clim=50) #deinterlace crop(2, 90, -2, -90) Spline36Resize(720,304) # Spline36 (Neutral) #denoise Tweak(sat=1.15, bright=5, cont=1.15) LSFmod(strength=100, smode=4, soothe=true, keep=80, edgemode=0, edgemaskHQ=false) -
Now it works don't know what happened but after starting to encode i get different error
script works on Media Player Classic -
Try SetMtMode(5) before ffVideoSource(), and SetMtMode(2) after. Ie, some filters don't work in some modes -- especially when encoding or using filters that may request frames out of order.
a. "RequestLinear(rlim=50,clim=50)" requires IVTC.dll and FFVideoSource should not require it (at least from my experience it is only useful when one of DGs source filter is used)
b. MT scripts should include one 'SetMtMode(X,Y)'-call and optional multiple 'SetMtMode(Z)'-calls
c. it is recommend to also define SetMemoryMax -
Hi guys i am getting the following error http://prntscr.com/3570p4
KernelBase.dll? -
I believe that's part of the 32 bit Windows(32)-on-Windows(64) virtual machine. The real bug is probably elsewhere, it just shows up in kernelbase.dll. Try removing script functions one at a time to see what's causing it. Then look for an alternative.
iam getting this FPS with AVSmeter http://prntscr.com/35cbs1 with SETMTMODE(2) CPu only at 13%?
I measured the processing frame rate by opening the script in VirtualDub and selecting File -> Run Video Analysis Pass.
now something happened getting good speed...even used FFT3d
AVS-METER= http://prntscr.com/35ci6p
VirtualDUB= http://prntscr.com/35chfi but crashes at the start after 5sec http://prntscr.com/35chpp but the script play on MPC
SCRIPT I USED
Code:SetMTMode(2) LoadPlugin("C:\Users\Administrator\Documents\Megui\tools\ffms\ffms2.dll") FFVideoSource("D:\Dwnloads\yumm_HD_1280.mp4") crop(2, 90, -2, -90) Spline36Resize(720,304) Tweak(sat=1.15, bright=5, cont=1.15) FFT3DFilter(sigma=2.0, plane=0, bw=48, bh=48, bt=3, ow=16, oh=16, sharpen=0, interlaced=false) LSFmod(strength=75, smode=4, soothe=true, keep=100, edgemode=0, edgemaskHQ=false) -
Did you try using SetMemoryMax? Also, try changing the number of threads, Different MT modes for different filters, etc.. Many filters have problems running multithreaded. Those are typical fixes you can try.
I had no problems with your exact (except the source filename) script. About 65 fps, encoding with x264 CLI at the ultrafast preset (so x264 wasn't a bottleneck).Last edited by jagabo; 29th Mar 2014 at 20:26.
I added SetMemoryMax(512)
still getting the kernelbase.dll error i am on windows 2012 server -
Does it also crash if you only go through the script frame-by-frame ? (not doing any jumping)VirtualDUB= http://prntscr.com/35chfi but crashes at the start after 5sec http://prntscr.com/35chpp but the script play on MPC
If it does crash comment out one filter at a time to see which filter is causing the crash. -
Then you might want to check the ram usage right before the crash.
My guess is that Virtual Dub might use to much memory right before the crash.
If the RAM usage is okay (below 2GB), there might be another problem.
Also add:
to the end of your script, to make sure there is no mixup with the threads.Code:return last
AnonymousGuest
Look at the memory usage in AVSMeter. It's already beyond the 2G user address space for 32 Bit apps. It only works because AVSMeter is linked with the LARGE_ADDRESS_AWARE switch. VirtualDub probably is not.
No you, should keep memorymax, but you should also lower the thread count
Help needed! Hacking LG BD390 to Multi region
By PANOS in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 08:35 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 10:33 -
Query about Multi-threaded vide codecs?
By goldenmean in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2010, 15:59 -
Multi-threaded video conversion - how to check it?
By usta in forum Video ConversionReplies: 8Last Post: 12th Nov 2009, 08:16 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46
