Page 1 of 4
1 2 3 ... LastLast
Results 1 to 30 of 106
  1. I would like to decrease the time it takes for scripts to run. Which one of these should I be using to get the best speed gains and compatibility with plugins? There's no point in me using them if they're going to crash.
    Which of these should I be using to achieve that?
    Avisynth 2.6 MT
    MT 0.7(+custom avisynth)a filter to run filters multithreaded. Usefull for SMP or HT
    SEt's Avisynth 2.5.8 MT compiled for *X86_64* :This doesn't seem to be maintained any more.
    These are the scripts I use which would need to work with any of the above programs:
    Mpeg2Source("I:\New\z = Encode\Raw January 13 1997 Fixed.d2v", CPU=6)
    TTempSmoothF(maxr=3, lthresh=8, cthresh=5, strength=4, interlaced=true)
    turnleft().nnedi3(dh=true).turnright()
    Load_Stdcall_plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
    AssumeTFF()
    Yadif(mode=1, order=1)
    mdata = DePanEstimate(dxmax=0)
    Vinverse()
    DePanStabilize(last, data=mdata, initzoom=1.05, dxmax=0, dymax=4)
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    afaik, avisynth 2.5.8 MT or 2.6 MT should both work ok.
    I use the 2.5.8 MT and get all my cores to work with no crashes by using
    setmtmode(5,0) just before the source line (in your example it would be the line before Mpeg2Source)
    and
    setmtmode(2,0) immediately after the source line.
    e.g. your example would become
    setmtmode(5,0)
    setmtmode(2,0)
    AssumeTFF()
    Vinverse()
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
  3. I've been using 2.6 MT.
  4. I have a dual-core PC with Vista 32-bit and 4GB Ram.
    I did what it said on this page and replaced the avisynth file in System 32 with the MT Avisynth file. I am now using the following script:
    setmtmode(5,0)
      Mpeg2Source("I:\New\z = Encode\Raw December 11 2000 Fixed.d2v", CPU=6)
      setmtmode(2,0)
      DeGrainMedian(limitY=2, limitUV=3, mode=1, interlaced=true)
      Crop(8,12,-14,-12)
      Tweak(Bright=0, Sat=0.7 , Cont=1.0, Hue=0.0, Coring=False)
      AddBorders(11, 12, 11, 12)
    I have a few problems:
    1. I like to see what my improvements look like before I encode the video by using AvsPmod. I get this script error: "There is no function named "setmtmode" on line 1" so I can't use AvsPmod.
    2. MT doesn't seem to support having borders or crops on both the width AND height. This seems silly. How am I supposed to use MT if I can't crop or add borders.
    3. I let the script run for a couple of minutes to see how high the frames per second speed would go up to. It was around 14 at max. However I got that speed before without MT! Am I doing something wrong? I am encoding h264.
  5. Get mt.dll and put it in your plugins folder. Crop and AddBorders works exactly the same as in the single threaded version. Without SetMtMode() you will get no improvement.
  6. Could you please point me to a page that offers that as I couldn't even see that mentioned on this page.
  7. Oh, sorry. I don't think mt.dll isn't required anymore. Maybe you need to reboot?
    Avisynth 2.6 (and hence 2.6 MT) does not allow odd numbers in Crop or AddBorders with YV12 clips.
    http://forum.doom9.org/showthread.php?p=1567181#post1567181
    mt.dll is not supported in the 2.6 MT version.
    It was never required for SetMTMode anyway, only for the separate MT() function.
    You shouldn't need to reboot when installing the MT avisynth.dll.
    However, you need to unload any currently loaded instances of Avisynth.
    (In AvsP: release all videos from memory).
  9. OK guys I restarted my PC (I have a dual core) and I'm still getting the same 17.88 fps speed with normal and MT avisynth.
    I have Avisynth 2.5.8. I replaced the system32 avisynth file with the MT 2.6 file. I am using this script with Simple x264 Launcher to make an h264 file:
    setmtmode(5,0)
    Mpeg2Source("I:\file.d2v", CPU=6)
    setmtmode(2,0)
    Crop(0,12,0,-12)
    Tweak(Bright=0, Sat=1.0, Cont=0.9, Hue=10.0, Coring=False)
    AddBorders(0, 12, 0, 12)
  10. Look at Task Manager. What's your CPU usage? Try using 3 threads on a dual core system -- SetMtMode(5,3). If x264 is your bottleneck speeding up AviSynth won't help much.
  11. I've replaced the avisynth.dll in the System 32 folder with the file from MT. However when I try to encode the video in Simple x264 Launcher it crashes and I get the following message "avs2yux_x86.exe has stopped working". Yet if I encode with HC Encoder I don't get any problems.
    I'm not sure what I've done wrong. This is my script:
    setmtmode(5,3)
    Mpeg2Source("L:\Raw 2001\01 Raw January 2001\Jan 8\Raw January 08 2001.d2v", CPU=6)
    setmtmode(2,0)
    McTemporalDenoise(settings="medium", interlaced=true)
    I had this working before then I restored a backup of my PC before I had it working. Now it's not working and I don't know why. The script loads in AvsPmod as well, it just crashes when I try to encode the video with Simple x264 Launcher.
  12. Video Restorer lordsmurf's Avatar
    I've run into some issues with bad frames on encodes longer than 12 hours on MT.
    The non-MT had no such issues.
    Same for the MT Huffyuv vs non-MT.
  13. Originally Posted by holygamer View Post
    setmtmode(5,3)
    setmtmode(2,0)
    Simplify your script. To just Mpeg2Source(). Any problems? If not, add McTemporalDenoise(). If no problems add SetMtMode(5,3). If still no problems add SetMtMode(2,0). If only that last command caused problems try changing SetMtMode(5,3) to "5,1", or "5,2".
  14. Thanks, I've solved the problem. I was missing a plugin and I also made the mistake of copying and pasting my script into Microsoft Word then copying it back into the avs file which somehow caused the encoding to fail.
  15. I spoke too soon. The following code works:
    setmtmode(5,3)
    setmtmode(2,0)
    However when I add the following to the bottom it crashes saying that "avs2yuv_x86.exe has stopped working".
    Using McTemporalDenoise without MT does not cause it to crash!
  16. Can you open it in VirtualDub? How about directly with x264?
  17. I had an MPEG2 and I saved the project file with DGIndex. I dragged the script in VirtualDub. It opens and I can see the video. How do I save the video? The only option I see is File, Save as AVI. I did that then the program crashed. Here's the crash screenshot: http://img151.imageshack.us/img151/3035/crashzt.jpg
    Apart from the Avisynth plugins do I need anything else to make VirtualDub work apart from the program?
    In Simple x264 Launcher MCTemporalDenoise works without MT mode. But with it, it crashes. HC Encoder doesn't crash but the resulting video has a whitle glow around all objects.
    I can use other scripts such as DegrainMedian with MT mode without crashing.
  18. btw. afaik instead of setMTMode(2) you need to use setMTMode(3) for the part of the script where you use MCTemporalDenoise,..
  19. So do I do this?
    setmtmode(5,3)
    setmtmode(3,0)
    Why do I need to enter 3? I'm sure the method I mentionedd before used to work but now it's not.
  20. Why do I need to enter 3?
    Because afaik, unless you use 3 McTemporalDenoise tends to be instable (crashes from time to time), especially if it's not the last filter in the script,...
    -> if mode 2 works for you without a problem use mode 2, otherwise I would try mode 3. (I'm not sure but from what I remember from my last time using McTemporalDenoise, mode 3 when using a specific option in it,.. might be the interlaced = true,..)
    Cu Selur
  21. Yes, multithreading is difficult to program for properly. Some filter used by McTemporalDenoise() appears to have a problem so trying different modes is in order.
  22. Originally Posted by holygamer View Post
    So do I do this?
    setmtmode(5,3)
    setmtmode(3,0)
    I tried the above but it still crashed. It doesn't look like MCTempoaralDeniose will work in MT mode. Is there any alternative filter I could use which does the same as McTemporalDenoise(settings="medium", interlaced=true)?
  23. than try, the other mode values and why do you set the second parameter ?
    if it crashes with all mode values try if it works without MT and if the script works with onlky the MPEG2Source call in it,..
  24. I will told to have setmtmode before and after MPEG2Source so that's what I did. Is it wrong?
    The script works fine without MT but crashes in MT mode.
  25. Source filters normally all need Mode 5, after that most other filters work with mode 2 if they don't work with mode 2 one has to try the other modes,..
  26. I tried different MT settings before and found that only the following gave any speed benefit over non-MT. I'm encoding h264 with a dual-core PC.
    setmtmode(5,3) Mpeg2Source("L:\Raw 2001\01 Raw January 2001\Jan 8\Raw January 08 2001.d2v", CPU=6) setmtmode(2,0)
    Do you know of a specific setting that will work?
  27. If you don't call other filters after the source filter no additional SetMTMode calls are required,..
    also depending on the application you feed the script to, you need to add
    distributor()
    to the end of the script,..
    for me it works with SetMTMode(3), but I don't use: CPU=6 and I normally don't have interlaced input, and if I have it, the first thing after loading the source (and color format corrections) is to deinterlace it,...
    Cu Selur
  28. I thought de-interlacing a video for viewing on a TV will cause a loss of quality or is there a filter I could use to prevent or minimize the quality loss? Is so could you please provide a sample script?
  29. Example script - generated with Hybrid and it's avisynth extension - for using QTGMC for Deinterlacing and Deblock_QED for non aggressive deblocking, with some comments I added:
    SetMemoryMax(768) #setting max memory, actually usage can get a lot higher
    SetMTMode(5,8) #setting MT Mode
    #Loading Plugins: I normally avoid autoloading stuff from the Avisynth/plugins folder, since this can cause problems, i.e. when putting the RemoveGrain.dlls there ;)
    LoadPlugin("G:\Hybrid\avisynthPlugins\DGDecode.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\LoadDll.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\AddGrainC.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\dfttest.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\DirectShowSource.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\EEDI2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\eedi3.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\FFT3DFilter.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\mt_masktools-26.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\mvtools2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi3.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\RemoveGrainSSE2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\RepairSSE2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\SSE2Tools.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\TDeint.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\VerticalCleanerSSE2.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\ffms2.dll")
    LoadCPlugin("G:\Hybrid\avisynthPlugins\yadif.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\DctFilter.dll")
    LoadPlugin("G:\Hybrid\avisynthPlugins\deblock.dll")
    #Loading dlls: these I load since  FFT3DFilter needs them and I don't like to have Avisynth stuff in my System folders
    LoadDll("G:\Hybrid\avisynthPlugins\libfftw3f-3.dll")
    LoadDll("G:\Hybrid\avisynthPlugins\fftw3.dll")
    #Importing scripts:
    Import("G:\Hybrid\avisynthPlugins\Deblock_QED.avs")
    Import("G:\Hybrid\avisynthPlugins\QTGMC-3.33.avsi")
    #Loading source: (setMTMode is still at 5, for general hints regarding mode see: http://avisynth.org/mediawiki/MT_support_page which is a good start even though it is not always right, i.e. they use MPEG2Source with mode 1, which never worked for me)
    MPEG2Source(d2v="H:\Temp.d2v")
    SetMTMode(2) #changing MT mode to 2
    QTGMC(Preset="Faster") # deinterlacing, see: http://forum.doom9.org/showthread.php?t=156028
    SelectEven() # since QTGMC normally is a bobber, I now throwing away half of the images
    Deblock_QED(quant1=24,quant2=26,aOff1=1,bOff1=1,aOff2=2,bOff2=2,uv=3) # soft deblocking, see: http://avisynth.org/mediawiki/Deblock_QED
    distributor() # adding distributor
    return(last) #returning content
    As a side note: A lot of people create their Avisynth scripts either through an encoder frontend or an Avisynth Editor like AvsPmod, to see the changes of their script directly.
    Cu Selur
  30. Banned
    Which statement in this script is using yadif? QTGMC at "faster" doesn't use it.
    https://docs.google.com/spreadsheet/ccc?key=0AsftVT5A1FqQdHRKTUdlUXVUaDlxUE43c0NsQ3dFR3c#gid=0
    With final output as standard DVD, the video might not play well on some player/tv setups. I'd test first.
    If holygamer doesn't like the slow speed of plugins like MCTemporalDenoise, he certainly won't like just-as-slow-or-slower QTGMC. You could try the ultra-fast preset, but results aren't quite as slick.
