Hi to all, advance thanks to resolve my problem,
I am using Sony Architect Pro for DVD authoring, I have subtitle content in MSWord with ASCII encoded. now, I have to import that file into Sony DVD Architect pro with out any changes. I tried, Subtitle workshop, Subtitle Edit... but, I don't know how to do this. please help me!
for example my subtitle content is like this...
@ 01/14/12
@ Marina ( Tamil )
@ MARINA BOB.01
@ TIME-CODE 25 EBU
@ START 01:00:00:00
@ First frame : 01:00:00:00
@ Last frame : 01:20:29:15
1.
01:01:56:03
01:01:58:22
#Greetings S(r)ingara Chennai
my love for you is extensive#
2.
01:01:59:01
01:02:01:15
#You are always exclusive#
You're saying you have to convert it to some subtitle format DVD Architect recognizes? I don't use the program for authoring and have never seen subs like that before. Some sort of obscure XML-based subtitle format, I would guess. Anyway, find out what your authoring program accepts. Next, find out the format of your subs. Ask the guy that gave them to you. Ask him if he can convert them to something else for you. Ask him what programs can accept them and convert them to something else.
What's the extension on these things? MovieSubtitle.??? And what does DVD Architect accept as input? If they're from a retail DVD, go back and get them in a more common format.
Maybe someone else will recognize them. I hope they're of better quality than the English language subs I've seen for Tamil movies, most of which are just atrocious. The two lines you've shown us aren't very promising.
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
