to convert to dvd and svcd compliant mpeg files, long time ago i used tmpgenc... i bet as of now much better and freely available alternatives exist... can some1 recommend a good mpeg converter?
i've stumbled upon an old comparison thread and they were saying hcenc was pretty good... so what's good nowadays?
HCenc is probably the best free choice. The program I prefer that can utilize HC is called AVStoDVD. You can output as complete dvd video or as mpeg files or even demuxed audio and video streams.
You can also use AviSynth scripts or files created by DGIndex to use as input for HCgui. This will give you the most detailed control, but HCenc only works with video, not audio, so you'll have to demux and work with the audio separately.
Don't know about svcd though. Not a format I use, so someone else will have to discuss that. -
HCenc is certainly capable of producing SVCD compliant video, but you will have to learn AviSynth scripting so you can write your own scripts for it. Note that it will complain that you are not producing DVD compliant video if you produce SVCD, but you can ignore the warning.
I haven't used this in many years but DVD2SVCD used to be the best program when it came to producing SVCD from various input files. -
Nothing wrong with TMPGenc Plus 2.5, it's still going strong. This doesn't mean it's perfect (you'll have to spend into 4 figures to get anything near perfect). Later versions from 4.0 on up have lower quality. TMPGenc tried to discontinue the product a while back, but sales were too good so the encoder is still sold online. 2.5's audio encoder leaves something to be desired, but I work with uncompressed PCM until later steps anyway. I've used others, including HCenc, but I won't give up TMPGenc's advanced image controls.
If you just want to convert to dvd/svcd compliant I've found avidemux is excellent. It's worked with every file (with whatever wacky codec) I've tossed at it that wasn't broken. Just use the mpg ps stream preset.
It's not the most friendly program for newbies ... which I don't think you are ... but it's a lot easier than learning avisynth scripting language.
Can someone recommend a DVD Converter that is compatible with Aegisub?
By Djard in forum SubtitleReplies: 3Last Post: 17th Jun 2011, 02:26 -
recommend a converter .MOV to WMV
By rikit in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 02:25 -
which converter for mpeg-4 h264
By jayman34 in forum Video ConversionReplies: 2Last Post: 27th Sep 2008, 08:10 -
Help with mpeg to avi converter
By ortus in forum Video ConversionReplies: 3Last Post: 8th Mar 2008, 03:49 -
Recommend a GOP setting for PAL-DVD/MPEG 2 files?
By Dark Alpha in forum EditingReplies: 1Last Post: 25th Jan 2008, 21:41
