I wanted to add a mltui-language subtitle to some movies (.AVI, .MKV, .MP4), I used Sub2divx once and it a fine job, eccept that it adds the subtitle to .AVI only and the output is .divx..
but this is not all, so know it dosen't work at all.
know i am looking for somthing that reads (.AVI, .MKV, .MP4) and gives me (.AVI, .MKV, .MP4) for output
i am not willing to burn dvds or blurays, just to add the multi-language subtitle to the movie
can any one help?!
Use multiplexers. For mkv use mkvtoolnix / mkvmergegui and for mp4 use mymp4boxgui or yamb (mp4box GUIs).
Just be aware that there's no all-in-one that works for all three - you will, as Baldrick mentioned, have to use different programs for each of the three container formats. And note that MP4 only supports a limited few subtitle formats, like SRT and ttxt, so if you want to include other types of subtitles (like, say, anything with formatting, text styles, etc.), they'll have to be converted to SRT/ttxt/etc. first.
If cameras add ten pounds, why would people want to eat them? -
thank you very much Baldrick, I tried mkvmergegui and it works like a charm.
And many thanks to you too Ai Haibara for the useful tip.
but guys i am still looking for somthing to work with .AVI as Sub2divx shows an error every time I use it.
and thanks in advance. -
Try AVIAddXSubs. I also used (some years ago, though) to mux SRT subtitle streams into AVIs for use with my DVD player using VirtualDubMod; I think you can do it with AVI-Mux GUI, too.
thanks Ai Haibara, I tried AVIAddXSubs and worked OK. but I didnt know how to add more than one subtitle to the movie, it seems that AVIAddXSubs can do it, it is just I couldnt fiuger it out.
Ty AVI-Mux GUI as Ai Haibara mentioned. It's what I use if I'm dealing with AVI.
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Tranlate Subtitle language
By Deaf Raiders in forum SubtitleReplies: 10Last Post: 25th Nov 2009, 10:04 -
Trouble adding language track into mkv file
By kruuth in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2009, 21:11 -
re-author DVD adding a new subtitle language?
By u2paddy in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2008, 19:05 -
Adding subtitle to a movie and use it only in a STAND-ALONE DVD player ?
By bradford in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 02:59
