GearSprout is announcing our first piece of video cleaning software: SproutConverter. This OS X 10.6+ application is designed to clean and remove video noise, video distortion, blank spaces, static, and user defined frames from video files. If there are any blank or distorted frames in a video, existing video editing software requires that you manually remove them. This process requires repetition involving manual search and removal.
SproutConverter removes unintended alterations of digital video files including blank spaces, static, noise, artifacts, feedback, errors, distortions, and other unintended deformities. The video sections are cleaned and then rendered to a format of the user’s choosing. It also functions as a video format converter so you can convert your file from one format to another with or without cleaning.
The full and demo versions of SproutConverter are available on our website at http://gearsprout.com or you may also purchase it on the Mac App Store at http://itunes.apple.com/us/app/sproutconverter/id525882005
A Windows version is in the planning stages and we'll be making an announcement once we have more information about it.
Results 1 to 1 of 1
homemade video needs a cleaning
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2010, 02:16 -
Feedback on software for converting Powerpoint Presentations to Video
By LJB in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 09:21 -
Taking video out of Premiere Pro 1.5 and converting with another software?
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 19:55 -
Cleaning up video from SLP recording
By buddycat in forum Video ConversionReplies: 3Last Post: 12th Oct 2008, 04:05 -
cleaning the video
By alp in forum Video ConversionReplies: 2Last Post: 25th Oct 2007, 18:49
