Hi,
i recently downloaded the nero aac codec but im not sure where to put it or what because when i open virtualdub i cant find it among the audio codecs. Does it need to be installed or something?
Thank you.
nero aac is a command line encoder, so you can't use it directly with vdub
AFAIK , there is no aac acm encoder (There are decoders)
You can either frameserve or use the vdub external encoder feature
http://forums.virtualdub.org/index.php?act=ST&f=5&t=18789& -
my setting to encoder in file
http://files.videohelp.com/u/214508/External%20encoder%20virtualdub.vdprofLast edited by odar733-3; 21st Feb 2013 at 09:02.
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41 -
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 17:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 16:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 13:08 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47
