Hi,
I wanted to know what for dvd-rip avi format the movie I downloaded, so I opened it with virtualdub and this error occured;
Coulddnt locate decrompessor for format MPG4 (Microsoft High-Speed MPEG4)
VirtualDub requiers a Video for Windows (VFW) compatible codec to decompress video. DirecShow codecs, such as those used by Windows media player, are not suitable.
Where and how do I install this VFW? And with which codec was this movie encoded?
Some info's please!
If you want to install the Microsoft MPEG4 codecs (& other legacy codecs) then visit
http://www.microsoft.com/downloads/release.asp?ReleaseID=31921&area=search&ordinal=2
or just download & install
http://download.microsoft.com/download/winmediatech40/Install/8.0/WIN98Me/EN-US/wmpcdcs8.exe
(Watch out for word wrap with the links)
Note that MPEG4 codecs 1, 2 & 3 will be installed NOT any DivX hacks.
Martin. -
I have both DivX (V4) and MS's MPEG4 codecs installed on my pc and they both work OK.
Martin. -
almost note the MS Mpeg codecs are locked and cannot be used to compress AVI
Microsoft's MPEG4 codecs versions 1 and 2 are both capable of encoding as well as decoding.
It's the version 3 codec that's now 'locked' so it can decode but not encode.
Version 3 was originally capable of encoding but Microsoft decided to 'lock' it to decoding only.
The old Version 3 can be found if you've got the patience to find it on the web.
That's the situation at present i believe.
(Currently using MPEG4 V2 for VHS captures myself).
Martin.
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
