Results 1 to 10 of 10
  1. Can someone guide me how to enable FF/FR for SVCD? I am burning with Nero 5.5.2.3 and using APEX-ad660. Or atleast give the link.
    Thanks,
    vcdPro
    Jun 2001
    Try using VCDImager. I used Nero 5.5.2.3 for a while but the lack of FF/RW drove me nuts. Anyway, I now use VCDImager and everthing works great (FF/RW, GOTO...) I use cdrwin 3.8D to burn the cue/bin.
    Nov 2000
    foster city, ca, usa
    vcdPro,
    Try using WinOnCD 3.8 for burning. I use it and can FF/FR with my apex 660, though the stop function does not work. I just use pause or power to do the same.
  4. Thanks guys, FF/FR drives me nuts too! I will try it today.
    vcdPro
    Feb 2001
    Victoria, BC, Canada
    Hi,
    I've been using VCDImager 0.7.7 (via VCD2XML 0.0.2 then VCDXBUILD) and CDRDAO 1.1.5. I'm still not able to FF or FR on my Apex 700.
    Any other suggestions?
    Thanx!
    _________________
    Varek
    Electonics Engineering Technologist
    Web Application Developer
    Videographer Wannabe
    <font size=-1>[ This Message was edited by: Varek on 2001-07-27 13:14:33 ]</font>
    Jun 2001
    st. louis, mo, usa
    are you creating your svcd layout and then making a bin file out of it?
    THIS IS HARDCORE
    Feb 2001
    No,
    I thought VCD2XML was doing that for me but now I suspect not... Could you give me a link to an article or vcdhelp thread describing how to do that?
    Thank you much!
    Varek
    Jun 2001
    I just use VCDImagerGUI. That is very simple and works great. I guess is not too good if you want to have menus. Also VCDImagerEasy is a good front end also.
  9. See the following threads for some similar info:
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=51664&forum=1
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49955&forum=1
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49307&forum=1
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49275&forum=1
    *** What I want to know: what goes in the SCANDATA.DAT file?
    <font size=-1>[ This Message was edited by: kitty on 2001-07-28 05:12:37 ]</font>
  10. I've tried to burn SVCD with VCDImagerGUI once or twice. I got FF/RW to work but not GOTO. Anyone have any ideas?
