Hi,
This is probaby a v dumb newby Q. Apologies in advance. Have spent hours trying to find the answer without luck.
I need to add some additional images to my .dsg file I created with DVD Slideshow GUI.
I created the .dsg file some time ago, and successfully exported it as a .mpg file-- which plays well.
But I now must add some missing images. When I try to open the .dsg file in DVD Slideshow GUI I receive an error message for every image: noting the images are missing. And the .dsg file is really small, so images have not been included as part of the file.
This happens with all my .dsg files.
1. How do I edit a file created with DVD SLideshow GUI to add the missing images?
2. Should I do something different when I next create the .dsg file, so that the images are not missing?
Help much appreciated.
C
The .dsg maybe just have a link to your original images. Have you deleted them or moved them?
Thanks for fast response Baldrick. Files are not deleted, and I don't believe I moved them, but some time has passed since I made it, so I can't be 100% confident. The image files are in a child folder under the folder where the .dsg file sits.
Is there any way to refresh the link? I have tried moving the .dsg file temporarily into the same folder as the image files, but I receive the same error message.
I REALLY don't want to have to recreate the slide show; it's 2 DVD's long and has over 550 image files. It took a great deal of time to make initially, and has music and transitions.....sigh.
Any thoughts on how to recreate the link for a successful open?
C
DVD SlideshowGUI - Random slides / images missing from the ISO file
By DaveHole in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2010, 05:30 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Audio missing when opening an Avisynth script in WMP & VirtualDubMOD
By aln688 in forum Video ConversionReplies: 3Last Post: 2nd Apr 2010, 05:09 -
missing smiley bbcode images
By lordsmurf in forum FeedbackReplies: 2Last Post: 31st Jan 2010, 05:17 -
DSG is not giving me the jpeg comment in subtitle
By minifig in forum Authoring (DVD)Replies: 14Last Post: 3rd Aug 2008, 17:37
