I can't find any, thanks
I got curious and looked at Newegg.com. I can't find even one card that has any two of these together on it. If you can find a card that has two of them, jump on it, but I think finding all 3 together will be impossible.
Does your PC have a lack of open slots for add-on cards? You might find a combo eSATA and USB3 card. And if your PC is new enough, you might have a PCI X1 slot, besides the regular PCI slots. eSATA X1 cards are fairly common, and that would leave you with a free PCI slot for one of the other interfaces. Firewire seems to be fading away in popularity, so maybe not a lot of cards out there for it.
Verbatim 3.5'' External eSATA & USB Combo Drive 1.5TB
By kyrcy in forum ComputerReplies: 2Last Post: 8th May 2010, 11:00 -
Verbatim 3.5'' External Hard Drive eSATA & USB Combo 1TB
By kyrcy in forum ComputerReplies: 3Last Post: 19th Feb 2010, 09:44 -
Can a pci esata card be both internal and external simultaneously?
By yoda313 in forum ComputerReplies: 9Last Post: 1st Dec 2008, 15:45 -
eSATA PCI cards
By piano632 in forum ComputerReplies: 4Last Post: 7th Jan 2008, 15:55 -
how to connect esata port on MB to external esata HDD
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Dec 2007, 13:45
