since i am using this version i was reencoding 1 conert 43GB 3 times and i choosed once custom once default 25GB
and i got 3 times same result 27GB result after compression and i cant burn it
whats up ?![]()
Results 1 to 12 of 12
The author does support on this thread:
http://forum.doom9.org/showthread.php?t=143716
You'll get faster response directly from jdobbs there.
edit: likely the first advice will be update to 0.40.10 as the issue may be fixed already.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
You can manually set the value it compresses to. Go to Settings -> Setup and change Custom Target Size to a value like 21000 Megabytes and see if that gives you a value under 25 GB.
There is probably a bug related to your particular BluRay. jdobbs himself is fine. However, Doom9 is not. If your BD disc is some kind of music video for an Asian singer who is essentially unknown in Western Europe and the USA, jdobbs will not have a realistic way to get a copy of your BD disc for testing. There is also a good chance that your attempt to point out a problem may get a lot of responses from unhelpful people who say it's your fault for not setting it up correctly. BD Rebuilder has bugs and jdobbs admits it, but his fans on Doom9 act like it's perfect and it never makes a mistake. It is rather random as to whether jdobbs will be interested in your problem or not. If you are lucky, he will be. If you are unlucky, he will never reply to your post and no one who does reply will say anything helpful. -
manual setting didnt helped too its alltime same result 27GB herre are logs :
25,5 GB (27 451 559 936)
[06-10-12] BD Rebuilder v0.40.10 (beta)
[20:23:17] Source: NEUJAHRSKONZERT_SONY
- Input BD size: 43,41 GB
- Approximate total content: [02:45:32.197]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7600]
- Quality: Good (Very Fast), Two Pass
- Decoding/Frame serving: X264/LAVF
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640
[20:23:17] PHASE ONE, Encoding
- [20:23:17] Processing: VID_00002 (1 of 4)
- [20:23:17] Extracting A/V streams [VID_00002]
- [20:58:49] Reencoding video [VID_00002]
- Source Video: MPEG-4 (AVC), 1920x1080
- Rate/Length: 29,970fps, 213 185 frames
- Bitrate: 13 972 Kbs
- [20:58:49] Reencoding: VID_00002, Pass 1 of 2
- [22:05:22] Reencoding: VID_00002, Pass 2 of 2
- [23:15:03] Video Encode complete
- [23:15:04] Processing audio tracks
- Track 4353 (deu): Keeping original audio
- [23:15:04] Multiplexing M2TS
- [23:33:16] Processing: VID_00005 (2 of 4)
- [23:33:16] Extracting A/V streams [VID_00005]
- [23:40:30] Reencoding video [VID_00005]
- Rate/Length: 29,970fps, 43 140 frames
- Bitrate: 14 788 Kbs
- [23:40:30] Reencoding: VID_00005, Pass 1 of 2
- [23:53:18] Reencoding: VID_00005, Pass 2 of 2
- [00:06:25] Video Encode complete
- [00:06:25] Processing audio tracks
- [00:06:25] Multiplexing M2TS
- [00:10:01] Processing: VID_00009 (3 of 4)
- [00:10:01] Extracting A/V streams [VID_00009]
- [00:12:38] Reencoding video [VID_00009]
- Rate/Length: 29,970fps, 15 409 frames
- Bitrate: 14 760 Kbs
- [00:12:38] Reencoding: VID_00009, Pass 1 of 2
- [00:17:26] Reencoding: VID_00009, Pass 2 of 2
- [00:22:15] Video Encode complete
- [00:22:16] Processing audio tracks
- [00:22:16] Multiplexing M2TS
- [00:22:54] Processing: VID_00011 (4 of 4)
- [00:22:54] Extracting A/V streams [VID_00011]
- [00:25:53] Reencoding video [VID_00011]
- Rate/Length: 29,970fps, 17 538 frames
- Bitrate: 14 756 Kbs
- [00:25:53] Reencoding: VID_00011, Pass 1 of 2
- [00:31:20] Reencoding: VID_00011, Pass 2 of 2
- [00:36:53] Video Encode complete
- [00:36:53] Processing audio tracks
- [00:36:53] Multiplexing M2TS
[00:37:40]PHASE ONE complete
[00:37:40]PHASE TWO - Rebuild Started
- [00:37:40] Rebuilding BD file Structure
[00:38:43] - Encode and Rebuild complete
- WORKFILES folder removed.
[00:38:43] JOB: NEUJAHRSKONZERT_SONY finished.
i was reencoding this 4 times now how many times do i need to encode this to proper this to <25GB? -
Then you have no choice but to go to Doom9 and ask for help. Pray that jdobbs cares about your problem. Again, if this is a video of an artist who's only popular in Asia (or to put it another way, the BD is not available outside of Asia) there may not be much he can do even if he pays attention to you.
I do have one more suggestion. By any chance did you set it up to remove any audio tracks or subtitles? I have seen BD-RB fail to compress enough when you do that due to a bug. Make sure that ALL the audio tracks and subtitles are left alone and I mean ALL as in EVERY ONE OF THEM. Then re-run BD-RB and see if it makes it small enough. -
Hi asiafan
Did you change the custom target size to e.g. 20,000 in settings --> setup ?
Cheers
Ennio -
Changing your computer's day/date should do it. I had to clear the CMOS a few weeks ago due to a power outage, and until I set the correct date, I got the "expired" message.
Agreed about Doom9, they're not about helping people. I've been a member for years and have never posted there. Still, there's a good deal of useful information to be had there, if you know what you're looking for.
Dunno about your specific problem though, sorry.Pull! Bang! Darn! -
changing in setup was pointless when same content was after any comppression [i done it 5 times]
they are doin to much to often updates in this rebuilder some1 should tell Jdoobs to not update something what is working
this expiring "thing" i dont know 4 what.Myself i would use even version from 2011
founded next BD which rebuilder even didnt saw extras content -
asiafan - DBrebuilder defaults to movie only backup on new installs. This is why it can't find the extras. You have to change the settings to tell it to do a BD-25 backup to find the extras.
bd-rebuilder problem
By mathbes in forum Blu-ray RippingReplies: 3Last Post: 12th Feb 2012, 04:15 -
BD Rebuilder shwing problem
By vikas.babu in forum Blu-ray RippingReplies: 24Last Post: 7th Apr 2010, 07:02 -
BD Rebuilder structure problem
By teicang in forum Blu-ray RippingReplies: 5Last Post: 3rd Aug 2009, 12:30 -
BD Rebuilder 22.01 Problem
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 2nd Jun 2009, 13:36 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
