Basically, I have hundreds of videos with uncompressed audio. I'd like some way to compress just their audio down to AAC or MP3, but leave the video stream completely intact. I know I can demux, compress, then remux, but that's kind of a pain for hundreds of videos. What should I do instead?
You could use MediaCoder. Add your files. On the Video-tab select Copy Video. On the Audio tab select MP3 (or LC-AAC). On the container tab select MP4. Press the Start button.
I'd probably use avidemux myself ... nothing against mediacoder,l don't know it much.
But this sounds like a lot of effort if you're talking about hundreds of files. The audio portion of those file is very small compared to the video. Just how short of drive space are you?
I prefer to use ac3 passthru for my dvd rips because youjust get better quality if you don't reencode ... all encoding loses quality. With some things I find it makes a difference.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 13:47 -
compress the .VOB file
By akakiami in forum DVD RippingReplies: 10Last Post: 19th Aug 2008, 08:30 -
compress mpeg file
By bountylord in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2008, 11:33 -
Compress Quicktime File?
By videodirector in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 20:29
