I've been burning some of my movies to blu and, for some reason, I'm having sync issues with MultiAVChd. It's not a major difference but enough for it to look weird.
Everything I'm recording is through the Hauppauge. I use Videoredo to edit. Then I put it into the program and it's not being reincoded.
However, for some reason, whenever I play it back, I'm getting problems with the HD stuff being just slightly out of sync. Nothing different with the regular mpeg-2 stuff.
When I look at the audio properties, I make sure that there's no audio delay.
Any ideas?
Can you try running the original file created with the Hauppage in MediaInfo? Maybe it says something about delays in the audio-section. In VideoRedo you can adjust audiodelays, or set them manually in MultiAVCHD. Perhaps this works?
Ennio -
The synch issue in MultiAVCHD has been known for years, there is a setting in the program that helps synch the audio but it doesn't always work. The author stopped development in 2010 so it won't be resolved.
I haven't used MultiAVCHD in a while but IIRC: double-click the audio properties and select "synch audio".
Problem with multiAVCHD...
By hiimbored in forum Authoring (Blu-ray)Replies: 7Last Post: 2nd Jun 2015, 10:14 -
sync problems with tsmuxer and multiavchd on .ts and .m2ts files
By MCnDaHouse in forum Video ConversionReplies: 4Last Post: 9th Jun 2012, 20:56 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
multiAVCHD problem
By obadvw in forum Authoring (Blu-ray)Replies: 2Last Post: 17th Nov 2011, 16:02 -
Is multiavchd a problem?
By volam1 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Oct 2009, 15:19
