  1. Hi,
    remember this topic i posted some time ago? well, after instaling the ffdshow encoder everything was working fine until now. All of the sudden the MPEG encoder has just disappeared from the options and cant use it anymore. I think its related to some programs i installed regarding this other topic here: Ripbot and Hybrid. What can i do to get the MPEG encoder back?? Please help...
    Thank you.
  2. Did you try re-installing ffdshow?
  3. Yes, it didnt work. I only get a MJPEG encoder. I really dont know whats going on.
  4. DECEASED
    Jun 2009
    Heaven
    [ nevermind ]
  5. Member DB83's Avatar
    Jul 2007
    Comparing that list to the list in my install of ffdshow you have lost a whole lot more than mpeg.
    Uninstall all programs recently installed AFTER you had the desired options.
    Uninstall ffdshow as well
    Reinstall ffdshow
    Solved ?
  6. Its working now. I really dont know what caused it . Thank you.
  7. Member DB83's Avatar
    Jul 2007
    Sorry, I can not read Swahili.
    I guess you do not like my brand of coffee.
