  1. Hello everyone. How to open mts files in VD? I'm using VD 1.9.11 and Avisynth 2.6.0. I tried ffmpegsource command but it comes out with an error: video track is unseekable. FFvideosource load only video without audio. Can someone guide me how to open mts files, what plugins i need to VD and AVS?
  2. Try using seekmode=0 with ffmpegsource.
  3. Originally Posted by jagabo View Post
    Opens video without audio.
  4. It's FFMpegSource2, and atrack=-1 for audio
    e.g
    FFMpegSource2("PATH\video.mts", atrack=-1)
    FFMS2 has known issues with transport streams, especially interlaced AVC. Often the framerate will be incorrect. Use FPSDen and FPSNum to correct for the fps issue, or AssumeFPS
    Or use DirectShowSource(), but you need your directshow filters sorted out (splitters and decoders), and it has issues as well (not necessarily frame accurate , and inconsistent)
  5. Originally Posted by poisondeathray View Post
    e.g
    Got the audio, thx. Another problem is can't save the video in VD. The operation stuck with infinite time.
    Edit: It's the mp3 audio codec causing this.
  6. You can install Lame ACM MP3 and it should show up in the vdub audio compression menu
    Remember to check file=>file information about the FPS, otherwise you have to adjust it in the script
  7. Yes there are little problems with audio synch. Audio interleaving option can fix that but still feels like its unstable. In all my mts recordings audio start first (about half second) then video. VD loading both together making it out of synch.
  8. Mrs Intel Core i7's Avatar
    Mar 2011
    Mainland E.U, concierge
    Ages passed by and this is second time i promise myself to write own plugin for vd. Of course,guides are out there
    I`m interested too for m2ts plugins because I wqant to keep 4+ghigaBytes starman on 1cd only.
