Hi I was wondering if anyone knew what the cause if of a recent problem I started seeing in my video playback the video is diagonally split from top left to bottom right and the images are like mirrored that is the bottom left of the image is appearing in the top right I will do a screen shot.
http://www.book-stores.com/pics/split-screen-issue.jpg
It ONLY shows up like this is certain playback media such as ManyCam but not on MPC Home Cinema.
But first I use the latest K-lite Codec pack
Here is the video DATA with such a problem
Video
Format : AVC
Format profile : Main@L2.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 7
Duration : 3mn 44s
Bit rate : 541 Kbps
Width : 450 pixels
Height : 360 pixels
Display aspect ratio : 5:4
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.134
Stream size : 14.4 MiB (81%)
Hope someone can help
Michelle
Results 1 to 1 of 1
Weird DVD Burner issue
By Noahtuck in forum ComputerReplies: 1Last Post: 8th Nov 2011, 19:52 -
Embedding Video for Cross Platform/Device Playback
By wyclef in forum Newbie / General discussionsReplies: 3Last Post: 4th Oct 2010, 18:45 -
Weird issue with DVD to H.264
By reakt in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 19:15 -
Very weird hard drive issue
By alegator in forum ComputerReplies: 3Last Post: 12th Jun 2008, 13:03 -
weird TV as a second monitor issue
By pheldd in forum Software PlayingReplies: 14Last Post: 6th Nov 2007, 05:48
![Computer details: Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP RTM)
Date 2012-06-09
Time 04:00
Computer:
Computer Type ACPI Multiprocessor PC
OS Service Pack Service Pack 3
Internet Explorer 8.0.6001.18702 (IE 8.0)
DirectX 4.09.00.0904 (DirectX 9.0c)
Motherboard:
CPU Type HexaCore AMD FX-6100, 1400 MHz (7 x 200)
Motherboard Name Asus M5A78L-M/USB3 (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR3 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset AMD 760G, AMD K15
System Memory 3584 MB (DDR3-1333 DDR3 SDRAM)
DIMM1: 4 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Type AMI (02/20/12)
Display:
Video Adapter NVIDIA GeForce GT 520 (1024 MB)
3D Accelerator nVIDIA GeForce GT 520
Monitor LG W2261 (Digital) [22" LCD] (2012182201)
Multimedia:
A Comp](/images/buttons/computer.gif)
