So my question is how do I split the video track (Of the Demuxed DVD) in a specific time letīs say I want to split the track from 00:00:00 to 1:03:43 remaining the original quality and then how do I split the audio in the same way (with out losing audio quality).
And after that wich software should I use to mux the audio and video track that I splt
My other question is, since the DVD I have is a music concert, it has two audio files one in 2.0 and the other in 5.1, Iīm planning on uploading it to youtube but my doubt is with wich audio should I upload it, and the other what output for video should I use.
Note: I want to have the same quality of the DVD on youtube, so thatīs my real question. Split a part of the DVD and upload it with the same DVD quality
Thanks in advance.
youtube uses flv and mp4 file format and low bitrate audio and video.so i don't think that you can get same dvd quality there
Use DVDShrink in Re-author mode, then select Start/End to extract a clip. As for audio YouTube only supports stereo, it also doesn't support AC3 or DTS.
http://support.google.com/youtube/bin/answer.py?hl=en&answer=55744
I would extract the clip and import it to Handbrake to convert to H.264/stereo/AAC. -
So dvdshrink will do the work with the extraction and handbrake the mux?
In other topics is there any video hosting, that can handle more formats of audio and video? -
If the files are already demuxed then DVDShrink won't work, do you have the original DVD folder(VIDEO_TS) from the DVD? In fact you don't need DVDShrink if you have the VIDEO_TS folder, handbrake can extract the clip(using time or chapter).
As for other websites, I don't know of any that support 5.1 or multiple tracks.
Side note: if the video is copyrighted it will get pulled from YouTube, maybe not right away but eventually. -
One option would be to rip in IFO (pay attention to that spelling) mode with DVDDecrypter - if your DVD doesn't use one of the bad sector copy protection mechanisms (unlikely but not impossible that it uses it). Rip as one long VOB with no splitting. You can use something like MPEGVCR or VideoReDo to edit both the video and audio at the same time. Those editors are not free though.
Since you probably don't own the rights to the DVD and the performance on it, I don't know that you should knock yourself out over this. It will very likely be a matter of time (days or maybe even hours) before you get notified that you've uploaded infringing content. -
Demux Quicktime .MOV into original MPEG-2 ??
By mob in forum Video ConversionReplies: 8Last Post: 6th Nov 2010, 21:50 -
Demux and cut mp4 files?
By kewlar in forum EditingReplies: 0Last Post: 30th Sep 2010, 17:51 -
Can't cut part with vdubmod?
By kkiller23 in forum EditingReplies: 1Last Post: 19th Sep 2010, 08:15 -
How to cut out a part from DVD?
By DjuKa in forum EditingReplies: 8Last Post: 23rd Oct 2008, 12:03 -
Original part# remote control f/ toshiba Sd -3960
By thebirdf in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2008, 16:17
