hello i found a VOB file ( 0.99GB ) and i want to split a small portion without any quality loss ( about 4 minutes part ) and with all audio streams. i have only vob file.so how can i do it ? please help
				Results 1 to 10 of 10
	Womble MPEG Video Wizard or MPEG2VCR with a frame accuracy.
	Editing software that cuts only on GOP boundaries will make a cut only at the first frame of an MPEG "Group of Frames". VOB/DVD visual data is arranged as several types of frames within the frame group. Not every frame in an MPG contains data for the entire image. The first frame in the group usually has full image data, but the following frames in the group have data only for the portions of the image that change from the initial frame. 10 to 16 frames in a GOP is a common grouping. There are some MPG editors around that will allow cutting on any frame ("frame-specific") and will re-render and re-organize Group #1 to have all the image data it should have. Frame-specific MPG editors usually cost $$, sometimes lots of it, but a very popular one is MPEG Editor v3 from TMPGEnc. There are others. Check the Tools and reviews sections of VideoHelp, access from the home page.
 http://en.wikipedia.org/wiki/Group_of_pictures
 MPEG file and image structure: http://www.fh-friedberg.de/fachbereiche/e2/telekom-labor/zinke/mk/mpeg2beg/beginnzi.htmLast edited by sanlyn; 23rd Mar 2014 at 13:28.
	It means, in effect, that you can't cut on any frame you might like, but only on frames spaced about half a second apart. In most cases that's no problem.
 Both of the cutters I mentioned are found at the same link. For VOB cutting I find the older MPEG2Cut easier and more intuitive to use. Try it and see if it does what you want.
	thanks sanlyn
 i tried old MPEG2Cut .but it adds dummy audio track.and new version works fine.thanks all
  encoding .VOB to .FLV with least loss in qualityBy altavistasf in forum Video ConversionReplies: 9Last Post: 15th Oct 2010, 18:33
  Can I get VOB to smaller file size with no loss of quality?By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 14:11
  Get .vob dvd to youtube w/o quality lossBy kenmtb in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2009, 03:28
  How to split audio for editing without loss of quality in video?By anindyanuri in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2008, 21:26
  Cutting VOB File without any quality loss? (ending credits)By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 23:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
