Hi Friends
I rip using handbreak but no audio, again ripped a different dvd audio is lagging or gone a bit wiered ,Please help me guys as i followed the guide also Is there any way i can sort this out please help.........
Results 1 to 10 of 10
Why not rip the DVD using something like DVDFab HD Decrypter or AnyDVD (assuming you're using Windows, as you don't quite mention what OS you're using in your Computer Details), and then take the result to Handbrake?
If cameras add ten pounds, why would people want to eat them? -
Hi thanks for your reply, i do this in my laptop win 7 Operating system x64 home Edition, Intel dual core processor 4GB RAM 250 HDD.Please help..........
How about helping yourself a tiny, little bit?
DVDs that you buy in a store are copy protected. HandBrake alone will NOT work on these type of DVDs.
It was already suggested that you use DVDFabDecrypter (there is a FREE portion of the program) FIRST....then use HandBrake.
Have you tried that yet? -
Did you just rip in dvdfab ... ie. only remove the copy protection, resulting in a video_ts folder containing the movie ... or rip and reencode? That could cause problems ... handbrake is a very reliable encoder. The encoder in dvdfab isn't that good.
That's why so many here recommend dvdfab hd decrypter (the free part) to rip/decrypt, then handbrake to reencode to mkv or mp4.
They may recommend other encoders but handbrake (or vidcoder, which is an older version of the same program with a different interface) doesn't have the steep learning curve the others do. Video encoding is actually quite complex.
If I'm ripping my dvds I don't bother reencoding the audio at all. Just use ac3 passthrough. The audio part of the file is going to be dwarfed by the video part anyway so why bother?
DV-AVI to M4V issie using Handbreak
By Marli in forum Video ConversionReplies: 2Last Post: 5th May 2011, 08:44 -
Handbreak 0.9.4 (Source)
By The.King in forum Video ConversionReplies: 27Last Post: 21st Jun 2010, 08:07 -
help encoding anime w/ handbreak
By Ronin Silfar in forum DVD RippingReplies: 22Last Post: 29th Jan 2010, 22:28 -
Handbreak MKV h.264 settings help
By darkdream4 in forum DVD RippingReplies: 0Last Post: 1st Jan 2010, 07:06 -
Queery regarding the video tool Handbreak
By Dnoscave in forum Newbie / General discussionsReplies: 9Last Post: 17th Oct 2009, 13:12
