Hey folks, I am new here and love the wealth of info here. Thnx!
I have acquired a "dead" AG1980. After I plug it in and hit the power button, the first thing I hear is a "hissing" from the power supply area. I don't assume this is normal is it? I suspected capacitors but once I got into the unit, I didn't see any "bulged" or "leaking" there.
If I try to play a tape, it loads and wraps fine. The "video" image displays for about a second on the tv screen then quits. Its as if the motors just start to turn the tape, then quit. I have tried several tapes with the same result. The tapes play fine in other units. I figure if this "hissing" is a capacitor/ power supply problem, couldn't that be causing not enough power to turn the motors?
Just tried again and now getting an Fo4 error.
Any suggestions would be grateful. Thanks.
Results 1 to 1 of 1
How much is a Panasonic NV-FS200 / AG1980 worth now?
By zeroprobe in forum RestorationReplies: 11Last Post: 24th Nov 2013, 12:54 -
Panasonic AG1980 Info
By braxus in forum RestorationReplies: 14Last Post: 15th May 2012, 10:23 -
Problem playing back JVC miniDV on Panasonic camera
By Ryuran333 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Feb 2010, 02:16 -
Panasonic FS200 (AG1980) tracking / noise issue
By JoseD in forum RestorationReplies: 0Last Post: 21st Jun 2009, 18:54 -
Panasonic DVD SA-HT743 stopped playing Original DVDS
By chankya in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 17:38
