Someone put a home video on a disc and asked me to convert it to play on a home DVD player...the problem is its a Windows Media icon...And I have no idea where to start or what to do ...even if it can be done?...Any suggestions of any type would be greatly appreciated...
Thanks,
BigDogz
Convert it? No problem.
Check out How To Convert to the left. And I quote:
Play it on a DVD player? Well it depends upon the player.With these guides you can convert(encode) almost any videoclip, AVI, DV, DVD, DivX, ASF, MOV (Quicktime), WMV or RM to VCD,SVCD, DVD, DivX, ASF or RM. If you get problems when converting read the guide and again and last ask on the forum.
Check out DVD Players Compatibility list to the left for you odds of
success. If you got a good (or even ok) one, you should be able
to create a VCD that plays. Look at the How To Author to do this
once you have converted your WMV file to a MPEG1 VCD file.
Good Luck :P
will .vob files alone play in a home dvd player?
By vincy in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2012, 06:04 -
Play MKV file on Home DVD Player
By ladkvayo in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Apr 2011, 07:42 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 04:54 -
Converting home movies etc to play on a DVD
By Andrew71 in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 08:51 -
Help converting home movie dvd to avi/wmv for web
By dancingbear0420 in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 14:35
