Windows 7 64-bit
MPC HC 32 bit, latest
m2ts from AVCHD camorder, 1080i
WMP can play it back with about 20% of CPU
MPC HC playback is about 1/3 of the speed with 100% CPU utilization
WMP is 32-bit so there should no problem with codec or driver.
MPC HC Filter shows MPC Video Decoder and MPC Audio Decoder is used.
What settings are missing?
Make sure the DXVA decoders are enabled. View -> Options -> Internal Filters (left pane) -> Transform Filter (right pane) -> h.264/AVC (DXVA), WMV3 (DXVA), etc. Exit and restart MPCHC for the changes to take effect.
I've all source and transform filter enabled.
I also disabled H.264/AVC(ffmpeg) but got same result.
If I choose filter -> MPC Video Decoder, got
DXVA settings
DXVA (H.264) Compatibility check -- drop down of 4 options
Disable DXVA for SD (H.264) unchecked
DXVA Mode: Not using DXVA
Video card: AMD Radeon HD 6250 Graphics (1002:9804)
I've tried each value of the drop down but all with the same results.
Then I went to my desktop machine which DXVA is working. Yet the 4 lines are the same above -- Not using DXVA (the CPU usage is less than 10%).
What could be the missing element?
ThanksLast edited by cheerful; 8th Jun 2012 at 21:32.
Solution: need to use one of the EVR
"EVR" is the fastest but it doesn't support some things like changing the alignment of the video within the MPC-HC window and it doesn't support MPC-HC's internal subtitle renderer.
EVR Sync may no longer be maintained.
The default is EVR-CP.
I can't use Arcsoft Video Decoder in MPC
By Lincoln Burrows in forum Software PlayingReplies: 1Last Post: 18th Jan 2012, 11:47 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 16:44 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
WMP/MPC won't play any mpeg video
By hhhgamewmx7 in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 11:36
