Hi! I'm aware that you can take multiple files and compress them all into 1 big file. But is there any way you can compress more then 1 file without making one big file, as in keeping all the files separated using virtualdub or something? I have quite a bit of frap files I'd like to compress, and doing it 1 by 1 will take a bit, so I'm just wondering if there's any way at all~
Thank you! (:
Just batch convert with something else like xmedia recode, vidcoder, format factory instead.
How to compress the DVD with multi-angle feature?
By UMO in forum Newbie / General discussionsReplies: 7Last Post: 22nd Mar 2010, 22:14 -
Resize/Compress VirtualDub help?
By GODDIS in forum EditingReplies: 8Last Post: 22nd Dec 2009, 06:37 -
VirtualDub: "The audio codec cannot compress the source to the desired
By user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 19:35 -
how do I compress multiple avi files with virtualdub?
By unloaded1 in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2008, 23:43 -
how to compress a video with virtualdub
By sharmine in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 05:03
