I'm an old fan of K-Lite codec pack, I began to use it right after the development of Codec Pack All in 1 is stopped.
Now I have a problem with the last version (8.8), for the first time, during installation it asks to remove the AC3 Filter because it contains something equal or better (Y or N).
If I answer Yes or No, after installation the AC3 audio of my DIVX plus Player stops working and the DIVX plus Converter stops working with an error code (usually after 1st pass).
I had similar problem when AC3 codec was not installed.
Is there a special steps that I have to take during installation for preventing this problem?
Everything else is working fine. I have the AAC ACM Codec 1.8 and AC-3 ACM Codec 2.1 installed. For sure the problem is from the new K-Lite because when I uninstall K-Lite and reinstall AC3 filter the problem disappear even if I reinstall older version of K-Lite (K-Lite 8.7).
Please don't tell me to stuck with older version because I'm very curious to know the reason of the problem.
Many Thanks in advance.
Regards,
Sorry
I couldn't delete the thread
This kind of stupidity happen when installing new codecs after a lot of (Vodka + Red Bull), Cheers.
Problem is resolved by selecting AC3 Filter as the default filter during installation.
Regards,Last edited by Timpot; 6th Jun 2012 at 23:33.
THanks for posting your solution...instead of deleting the message text. It might help others who search for similar problems.
Problem installing Real Alternative Lite.
By csh in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2010, 13:24 -
Lite-On A110 DVD recorder, problem with RW discs
By Jack_Dante in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Apr 2009, 10:50 -
Lite-On LVW-5115GHC+ timer programs problem
By smik in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Oct 2008, 22:39 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 14:02 -
Lite on HD-A740GX input question/problem
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:32
