Does the extension of mpg on a Mac mean it is mpeg-2 or lower resolution?
Do you know what they call the files on a Mac that are mp4 quality?
Like on Windows, MPG and MP4 are containers that can contain anything from very low quality to very high quality audio and video. The container says nothing about the quality of what's in it.
You will need a program that can identify the codec that was used inside the container. It will also let you know the resolution and codec that was used.
Unfortunately for you I am a windows person so I don't know of which program will do this on the mac.
For windows you could use:
gspot
mediainfo
Also players like mpchc and vlc can tell you the details of the video itself.
One of these probably has a mac version of it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
MPG could mean MPEG-1, MPEG-2 or even MPEG-4, although the last one would be uncommon. I'm not saying this is likely, but there's nothing to stop a person from putting .mpg at the end of ANY file, even a file that actually contains no video.
As with many things, this task is harder on a Mac than on a PC. I'd suggest installing VLC on your Mac and letting it identify the video and audio by playing the file and looking under the Codec Information setting under Tools while it plays. -
Thread moved to the mac forum where you can get more help.
A Mac tool that can author .mpg to DVD folder for buring
By Sam0403 in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2012, 15:49 -
Playing MPG on Mac - converstion to AppleTV
By brstephe in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 22:01 -
convert mp4 to mpg / DVD (mac)
By tou in forum ffmpegX general discussionReplies: 2Last Post: 29th Aug 2010, 19:57 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 08:33 -
Sony .MPG files don't work on Mac? Is that true? Can I convert them?
By zernalaw in forum MacReplies: 2Last Post: 30th Nov 2007, 14:15
