I am using Uleads DVD movie factory to convert avi captured from a Panasonic DV camcorder into VCD. When I play the disc on either a computer or my dvd player the video quality is very poor (large blocks are seen). I was under the impression that the quality of VCD was at least as good as VHS. Am I missing some configuration during the translation process, or am I burning at too high a rate (12X) or is this the quality that vcd produces?
dbagn,
Compliant VCD @ 1123 kbps does not produce great quality, however, if your DVD player will play XVCD @ 2300 kbps encoded from uncompressed AVI the final product will be just under that of the source material. Try re-encoding the avi @ 2300 kbps.
How fast your burning 4x, 8x, 12x should not matter.
Also, if your capturing directly from camcorder to the compliant VCD specifications this will barely be watchable.
Gary Spicuzza
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Large size difference in mov and mpg, no apparent loss of quality.
By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 10:19 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27 -
Please, best options for mencoder? (high quality reencodings and no blocks)
By BlooderButcher in forum Video ConversionReplies: 1Last Post: 21st Nov 2008, 14:53 -
How to get large avi to fit on dvd while keeping quality
By BrettO in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2007, 09:54
