Hi,
Looks like I'm still struggeling to get this video conversion thing to a point where I can actually convert a video and watch it on my tv!! Since it's something I won't do very often I was about to give up but now it's become personal and I won't quit until I get it down!
So here's my issue. I had an mkv file which I converted to avi divx so I could put it on my Lacie Lacinema (not the new Lacinema HD version but the older "non HD" one) and watch it on my tv. I thought this went just fine because I could watch the avi file on my mac. Also my Lacie supports external subtitles and that alse works just fine.
On my computer audio and video are in perfect sync. However after copying the file to my harddrive the audio and video are way out of sync. I've been reading up on this but haven't found any solutions.
Anyone here have any ideas?
One topic got me thinking about fps. In my conversion settings I set fps to 30. I figured the more the better. Since I'm in Europe I think we use the PAL standard, which I think is 25 fps, isn't it? Could that be the reason?
I posted this in the mac forum since I use a mac but it's kind of a general question so sorry if I'm in the wrong subforum.
Din.
I tried changing the framerate to 25 fps but it makes no difference.
Anyone? -
If the file is in sync on the mac, it' s not a framerate issue, it's a device playback issue
Did you convert it to SD? If the device is the non-HD version, you should use settings compatible with it -
divx avi can come in HD resolutions as well
If your device is "DivX certified" then use the DivX standard definition home theatre profile, and it will attempt to optimize compatiblity
So obviously you have to use non HD...not the new Lacinema HD version but the older "non HD" one -
First off, thanks for your attention to this matter and sorry for my late response. Where I am it was getting late and I went to bed.
I used Easy Video Converter to do the conversion. As far as I know it has no presets to set everything. You have to set all parameters manually with little dropdown menus. I'm not on my mac right now but here's my settings IIRC :
Video :
divx avi
720x400 (I think, 720 I'm sure, 400 not) it's a dropdown menu where you can choose.
25 fps
Audio :
mp3
44100 kHz
128 kbps
Would that be alright?
EDIT : the funny thing is that the device actually goes up to 1080p. But I once forgot to change the imagesize tab and left it on "keep original size". The device complained that it doesn't do bigger than 720x576 and won't play the file.Last edited by Din Viesel; 7th Jun 2012 at 03:34.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
Audio Sync Problem That I Do Not Understand
By Anakin in forum DVD RippingReplies: 20Last Post: 25th Feb 2009, 10:32 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
