Hi I'm new here, and I'm using VLC player, mkvmerge gui and Format Factory converter. So I downloaded a movie mkv file and I want to play it on my blu-ray player that does not play mkv. So I always convert them to avi. I never had a problem. But then yesterday after removing subtitles with mkvmerge, the weirdest thing happened. When I try to convert the mkv to avi this happens:-
1) First it reaches 100% within less than 10mins,
2) Then it creates an temp avs file in the output,
3) It returns to 0% and takes forever to convert
4) When I tried to view the undone file it says avi index broken or missing
5) but after a long wait it does convert, why
The last time I converted a mkv to avi I did the same thing, remove the subs and it worked fine and fast
What happens if you convert without removing the subs? I guess format factory hard code subs?
And if you have a blu-ray player you could try convert the mkv to an avchd with for example avchdcoder or https://www.videohelp.com/tools/sections/all-in-one-mkv-to-mp4-avchd-ts . No reconversion. -
Then it converts normally, it's also does it faster. When I take out the subs it does that funny thing creates a temp file and basically slows the converting process down. Not a serious problem but it's funny, but some files are unaffected? Weird Lol
You can try disabled header compression in mkvmergegui, under file->options->disable header removal by default. Restart mkvmergeui, remove the subs, make a new mkv and then try convert it.
Removing chapters from BDMV format
By thepreacher in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Feb 2012, 10:16 -
Adding subs to avi format?
By Avon in forum SubtitleReplies: 2Last Post: 14th Aug 2011, 12:20 -
Removing Subs to reduce MKV size / other options?
By kmcc in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 16:55 -
removing audio or subs with mkvtoolnix causes prob in media players
By lordhutt in forum Video ConversionReplies: 3Last Post: 21st Feb 2011, 19:05 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17
